SpeedoHealer question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 08-21-2006, 06:03 AM Thread Starter
Heavy's Avatar
I installed a 43 tooth rear sprocket on my V a while back. I figured I'd put on a Speedo Healer at the same time to compensate for the increased speedo error.
My question is regarding induced odometer error from the Healer. I figured I had about 13% total speedo error so I set the Speedo Healer for a -10% correction, figuring it would make me close to accurate and still leave a little margin for error. Since the odometer is pretty accurate from the start and I introduced about 5% error with the sprocket, would I be correct in assuming my odometer now reads about 5% under the actual mileage?
Let me know if you think my reasoning is correct.
DL1000K6
Heavy is offline
post #2 of 2 Old 08-21-2006, 10:26 AM
I'd think it would be more accurate to just go out on the highway and check the odometer reading against the mileposts.
