Givi / MadStad mods - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 08-14-2006, 06:12 PM Thread Starter
DrDale's Avatar
Send a message via AIM to DrDale
Givi / MadStad mods
Just installed Givi V-46 tail case, Givi crash bars and Madstad adjustable windshield bracket.
Two thumbs up on the Madstad! Big improvement in buffeting and wind flow. Not much increased turbulance as speed increases. I have it adjusted a bit below half way up, most of the way back.
Givi V-46. Nice trunk. vague installation instructions, but fairly easy installation. Best to take off the entire back rack and grab rails to do the job. Probably should've got the E-52 big mongo.
Givi crash bars. Installation fairly straight forward - torqued everything to specs posted on this site - 25 ft lb. noticed a bit of vibration, mostly in the footpegs, but some in the seat also. Just returned from a 300 mile trip, including some high speed expressway riding. Vibes got REALLY BAD at 75-80 mph. Especially in the handlebars. Did about 50 miles at this speed. Some numbness and ache in hands and forearms presisted for over 3 hours after ride was finished. Reaching down to grip the crash bars - very noticable hard vibration. I may try some of the fixes I've seen posted here - rubber washers, silicone at the front joint, ect. More likely I'll just remove the bars and ride without. I have a 1,000 mile ride from here in Michigan to Illinois for the flat-track Nationals Labor Day weekend. Couldn't tolerate a ride of that distance with these vibrations.
Not sure at this point, but...I'm inclined to sell the Givi bars and try the SW Motech - nothing bad posted about them (except they don't have as good of crash protection as the Givi. I believe I saw a couple of posts regarding tip-overs with the Motech bars that didn't adequately protect the fairing. Thinking about it....one crash trashes the set of bars to the tune of about $150 (w/shipping). My insurance deductable is $250 - so I'm only really saving $100 IF I do a tip-over. Not sure if it's worth it. Certainly not worth the vibration and aggravatioin.
Also....I'm 5'6" and no real problems with the height of the 650 V-strom (new April 06). Now that the suspension is broken in and set properly, it's not that bad. Important to adjust for a passenger or solo. I'm coming from 30 years of riding dirt bikes - all of which are pretty tall.
All that said...I love this bike. Getting better all the time.
Comments and suggestions (especially regarding the crash bars) welcome.
DrDale is offline
post #2 of 15 Old 08-18-2006, 11:12 AM Thread Starter
DrDale's Avatar
correction
Opps! Found out I'd inadvertently left the cross-bars that came on the Givi braces on when I initially installed them on the bike. The back of the instructions say "WARNING" the flat cross bars must be removed before installation....... DUH! I should've known better. Apoligies to Givi.
I'm going to reinstall the crash/engine guards. I've ordered new stainless steel bolts and picked up some rubber washers from the hardware store. Should solve the problem.
DrDale is offline
post #3 of 15 Old 08-18-2006, 10:18 PM
Hey Doc, you have me baffled. What cross bars ?? Part of the bars, part of the bike ? Never did read the back of the instructions. On a 650, right ?
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #4 of 15 Old 08-21-2006, 03:42 PM Thread Starter
DrDale's Avatar
WW - the bars came with a flat black bar which connected between the two inner mounts (of four) on each side crash bar. You know....there are four mounts (with bolts) on each side - two are sort of back/lower, two are front/upper. the bar connected these. I initially thought that this bar was actually something new to REDUCE the dreaded Givi bar vibrations. Apparently, it must be something that's included in shipping, perhaps to help the bars keep their shape during the shipping process, not sure tho why it was included. I've seen some pictures posted on the site showing the crash bars installed with this bar showing. It's supposed to be removed before installation.
DrDale is offline
post #5 of 15 Old 08-21-2006, 03:42 PM Thread Starter
DrDale's Avatar
WW - the bars came with a flat black bar which connected between the two inner mounts (of four) on each side crash bar. You know....there are four mounts (with bolts) on each side - two are sort of back/lower, two are front/upper. the bar connected these. I initially thought that this bar was actually something new to REDUCE the dreaded Givi bar vibrations. Apparently, it must be something that's included in shipping, perhaps to help the bars keep their shape during the shipping process, not sure tho why it was included. I've seen some pictures posted on the site showing the crash bars installed with this bar showing. It's supposed to be removed before installation. Yes.....650
DrDale is offline
post #6 of 15 Old 08-25-2006, 11:45 AM Thread Starter
DrDale's Avatar
OK....tried the rubber washers, o-rings on the center spacer thingy, proper torque on the bolts, ect. Still has some noticable vibrations, first noticed in the footpegs, then the seat, then the handlebars. Taking the Givi crash guards off - gonna put them on e-bay when I get back from my trip to Illinois. 1,000 mile round trip. Just don't want to deal with the vibes for a ride that long.
I may try the Motcech guards at a later date, maybe not.
DrDale is offline
post #7 of 15 Old 09-13-2006, 08:36 AM
pilbaralad's Avatar
Givi Crash Bars
How did you go with removing the bars? replaced them with something else yet? I would be interested to hear if anyone else has had this problem.I am about to order the 650K7 and was ging to have the crash bars fitted for delivery but now I'm not so sure.
Cheers
Brett
DL650K7, OEM centrestand, Givi crashbars, Ventura rack and bag,SW Motech Quicklock Tank "Trial" Bag, Oxford Soft Pannier Bags, Ventura headlight guard, Dan V Skidplate, Dan V Radiator and Oil Cooler guards, Dan V Luggage protector, Hyperlites, Madstad windshield bracket, Eagle Screen, Pyramid Fenda Extenda, Crampbuster, Kaoko Throttle Lock, Acerbis Handguards, Bicycle handlbar Highways Pegs Mk II, Autocom & UHF CB, Pacsafe.
pilbaralad is offline
post #8 of 15 Old 09-13-2006, 08:55 AM
Martin's Avatar
Re: Givi / MadStad mods
Hope the 46 works out for you but I went with "big mongo" and am glad I did...
My bike boots, pants and jacket can be crammed into it but just barely; there's no way it would all fit in a 46 litre case and it's really convenient to be able to hide all my riding gear (except for the helmet) in there and walk around in street clothes or go hiking.
- Martin
2019 650X
Martin is offline
post #9 of 15 Old 09-13-2006, 07:34 PM
Dr. D........Interesting. Apparently I did not get the extra pieces that you got. My bars came wrapped up real snug in a whole lot of plastic wrap.
05 / 650 in blue
75/Suzuki 125 RV
post #10 of 15 Old 09-13-2006, 07:43 PM
Pilbaralad, get the bars or another brand soonest. Crash bars will save your bank account if the bike gets dropped.. The bad vibes do not show up on all bikes. My bike has some vibes but I won't take them off. After a dead drop on concrete with the bars on I shudder to think of the damage without them. It only cost me a clutch lever, not a fairing.
05 / 650 in blue
75/Suzuki 125 RV
