Suggestions for Improved Braking Performance - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 08-10-2006, 01:21 PM
doolittj
Does anyone have any tried and true suggestions for improving the braking performance of the DL1000? Braking is the only "weakness" I've found with my '05 (it's not really bad per se, but could be better). I'd like to improveve both the "feel" of the slightly wooden front brakes as well as their power. Do braided stainless lines help? Are there better front calipers that others have found? Obviously I don't want to overpower the skinny front or anything though.
post #2 of 7 Old 08-10-2006, 01:57 PM
Heavy's Avatar
Probably best to start off with better pads and braided lines. You might be satisfied without the expense of calipers.
DL1000K6
Heavy is offline
post #3 of 7 Old 08-11-2006, 09:44 AM
BlackCatRacing
Ditto what Heavy Said
EBC HH Pads in Front
Braided Steel Lines on both the Front and Rear
Radial Master Cylinder from GSXR 600/750
Galifer Wave Rotors on Both Ends
High Dollar Brembo Rotors and Calipers
Boat Anchor on Tail Rack with short chain
Ride Em
:twisted:
post #4 of 7 Old 08-11-2006, 12:30 PM
Kawidad's Avatar
I did the braided SS lines in front and rear and was disappointed. There was a noticable lack of improvement. Pads with the lines might be the ticket.
A new master cylinder is another cool idea, but what donor bikes and what years are another question. Black, any further info???
Kawidad
2007 DL1000K7
Kawidad is offline
post #5 of 7 Old 08-14-2006, 11:28 AM
doolittj
Should I go with a Danforth or a mushroom anchor?
post #6 of 7 Old 08-14-2006, 11:40 AM
Colin's Avatar
I would have to say go with the Mushroom. The Danforth tends to get caught in the spokes.
Colin is offline
post #7 of 7 Old 08-14-2006, 01:20 PM
Albie's Avatar
I can't see the reason for adding braided lines to the rear, unless you're going for bling.
Albie
'05 DL 650
'06 DR 650
'07 GSXR 600
'07 KTM 450 EXC
'08 KTM 690 E
'09 KLX 250S
Albie is offline
