How to remove OEM heated grips without damaging them - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 11-12-2010, 06:10 PM Thread Starter
I just got some new handlebars (MSR ATV Low Carbon Steel) and want to install them. I have OEM heated grips on the stock bars. What is the best way to get the one on the clutch side off without damaging the elements. I want to install the OEM heated grips on the new bars. Tips, tricks and guidance would be very much appreciated!
Are the heating elements made into the interior of the OEM grips are are the elements on the interior surface?
In the past when I have removed grips, I have stuck a very thin screwdriver in between the grip and the bar and used brake fluid cleaner to loosen the glue. Would that approach be safe to use with the heated grip on the clutch side?
Thanks!
Vic
Vic5491 is offline
post #2 of 13 Old 11-12-2010, 07:15 PM
WeeMcD's Avatar
Not sure about loosening the glue, but the air compressor has always been my friend for removing grips. Give it a shot.
2007 DL 650 SOLD with 56k miles
2012 DL 650
1991 DR350S (dirty bike)
2004 DR 200 (wife's dirty bike)
Janitor, writer and editor of BestScenicRoutes.com. Explore It. Experience It.
Real name: Sean McDermott
WeeMcD is offline
post #3 of 13 Old 11-12-2010, 07:54 PM
Go ahead and damage them taking them off, they are junk anyways.
post #4 of 13 Old 11-12-2010, 08:22 PM
Living the Stereotype
Stromin'Nroman's Avatar
Skinny flat screwdriver and WD 40 with a spritzen tuben.
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #5 of 13 Old 11-12-2010, 09:16 PM
toycloser's Avatar
I would heat them up real good then give em a twist.
2007 Aprilia Tuono (black) 20k
2005 Suzuki V-strom (black) 53k, still going...
notice a trend?
toycloser is offline
post #6 of 13 Old 03-08-2011, 05:06 PM
OEM heated grips vrs throttle lock (cruise mechanical type).
Anybody know what throttle lock would work best?
I currently have a 'crampbuster' on but have not used it yet. Too much snow and ice yet.
Also am curious what is objectionable about the OEM heated grips?
Thanks
Montana73 is offline
post #7 of 13 Old 03-08-2011, 06:18 PM Thread Starter
OEM Heated Grips
My OEM heated grips work just fine. The only objection I have to them is they cost so much. They were on my bike when I bought it. Had they not been, I would not have paid the premium for them over cheaper alternatives that are probably just as good.
I'll be curious to hear what people suggest as a good throttle lock.
Vic5491 is offline
post #8 of 13 Old 03-08-2011, 09:14 PM
10-95's Avatar
+1. Never got the air thing to work. You can easily clean the grips with soap/water/clean rag and the WD comes right off.
10-95 is offline
post #9 of 13 Old 03-09-2011, 08:41 AM
Chewy's Avatar
This is the method that I've used numerous times with a long skinny screwdriver....WD-40 is harmless and easy to clean up.
Chewy is offline
post #10 of 13 Old 03-09-2011, 08:52 AM
tmcgee's Avatar
Thanks
They only heat halfway around.
tmcgee is offline
