Tool tube bracket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 11-02-2010, 10:10 AM Thread Starter
Tool tube bracket
I broke my Dan Vessel tool tube bracket. Overloaded it with a water bottle in the tool tube, and a washboarded road. So anyone beef this up so it can handle the abuse? It's made from pretty thin walled tubing, so welding on it could be tricky.
oldmanb777 is offline
post #2 of 4 Old 11-02-2010, 11:00 PM Thread Starter
Welded it back together today, and added a doubler. I think not putting heavy things in it is the answer. A water bottle and washboarded roads killed it.
post #3 of 4 Old 11-04-2010, 09:22 PM
I was notified of your dilemna by another Stromer on this site. Your storage tube guard is the 3rd one I have heard of that has cracked near the crimped end in almost 5 years we've been producing them. But those two were enough that I instituted a fix for this a few months ago and it was actually quite simple. On the standard sized tubing we inserted a steel 1/8" insert into both ends of the tubing, extending past the crimped area, just prior to crimping. This in effect beefs up both mounting points of the storage tube luggage guard, as well as the Agri-Tube luggage guard. Initially I started using a larger diameter, 3/4", tubing to remedy this possible condition but found it was overkill, appearing too large when mounted to the Strom.
I have replaced the other two guards at no charge and would be happy to send you a replacement if you would like, just email me at [email protected] and we'll get a replacement in the works for you.
I look forward to hearing from you soon.
Dan
trailbuster30 is offline
post #4 of 4 Old 01-24-2011, 08:04 PM Thread Starter
Dan, I appreciate the offer, thanks. I have it fixed for now and working. I believe I over loaded it, and thus the failure. So my fault. Thanks for standing behind your products. If I have a further issue with it, I'll let you know. Norm.
