Can you see me now!!?? 4x 3 watt cheapie LEDs - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 10-23-2010, 11:00 PM Thread Starter
So, I decided to replace my H3 halogen driving lights with some LEDs. The halogen were just drawing too much power; 35 watts on each side, + heated grips, GPS, USB BlackBerry charger, head lights etc.
I ordered 4 of these:
from LED Module Aluminum Housing High Power
So then I was trying to figure out how to mount them. I took the bulbs out of my H3 lights and saw that the hole in the back was about 5/8 of an inch...Lights are close to 1". Hmm.
Realizing that if I messed this up I would have NO lights, I broke out the trusty Dremel and hacked a bigger hole in the back of the housing. Some two-sided mounting tape to provide some cushioning and some stick-to-it-iveness and voila!
So that takes care of two of them. I wanted to mount two others higher up on the bike, so I wracked my brain trying to come up with a mounting solution.
I finally decided to go low tech and bought a couple of 1" pipe brackets from Home Depot. I decided to mount the two remaining lights on the hand-guards.
Seems brighter...
The light doesn't get thrown far down the road, but whith the hibeams on, these little lights seem to light up the near and middle distance.
The first guy on the block with a 2010 white V-Strom
Philander is offline
post #2 of 10 Old 10-23-2010, 11:04 PM
ozart's Avatar
From the website:
Warning! Maximum voltage is 14V DC! Any more causes destruction of the voltage regulator and LED!
If that's true, they aren't gonna last long.
ozart is offline
post #3 of 10 Old 10-23-2010, 11:11 PM Thread Starter
I suppose that remains to be seen.
post #4 of 10 Old 10-24-2010, 03:39 AM
I used simple LM317 regulators to make sure the voltage stays below 14VDC. I have the same LED's, four of them actually, they'r still working.........
[SIZE="2"]2009 ABS DL650[/SIZE]
Arne is offline
post #5 of 10 Old 10-24-2010, 10:29 PM
maggot's Avatar
Can one get these lights in amber?
Ken
2007 DL650 Gray
maggot is offline
post #6 of 10 Old 10-25-2010, 07:38 AM Thread Starter
Ken
Yes. I also ordered one of the low profile 1 watt lights in RED. As soon as my Eastern Beaver tail light adapter gets here, I'm going to hook it up as a second brake light somewhere on the rear fender.
post #7 of 10 Old 10-25-2010, 09:26 AM
enumclaw's Avatar
I've been using the same lights for a year or so, about 20k or so miles, no problems. I just recently got a pair in amber, and also a pair of their 3W version to try out. Nicely done, btw, installing them in the old fixtures.
Rob
Ride every day, it's good for you.
07 650A | KLR250(x2) | KLR650 | DRZ400 | FJR
enumclaw is online now
post #8 of 10 Old 10-25-2010, 09:38 PM Thread Starter
Better night time pic. I think I need to angle the LEDs on the handguards up a bit.
For the price, I'm happy.
post #9 of 10 Old 10-26-2010, 11:08 AM
How much additional light do they provide from the riders perspective?? are they as good as a set of Halogen piaas ? Or are you just adding them for daytime triangulation effect on cages. ??
Kieth is offline
post #10 of 10 Old 10-26-2010, 12:54 PM Thread Starter
My intent was more to be seen, rather than to see. That being said, they do throw a fair amount of light in the near distance. They light up that dead-spot that you get when the high-beams are on.
I commute to work early in the morning while it's still dark and then come home in the dark as well. I wanted something bright and noticeable so that cagers would see me.
One of my co-workers said that bikes like mine are how UFO rumours get started, so I guess it's noticeable!
