Heat Troller Question... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 10-22-2010, 10:13 AM Thread Starter
Can I cut the coax end off a heat troller output wire and connect to heated grips? Anyone know wich wires are hot and neutral?
'07 Vstrom 650
jmo3373 is offline
post #2 of 4 Old 10-22-2010, 11:45 AM
The center connector on the coax plug is hot. That's to protect in from contacting the grounded frame. Cut it off and polarity is unimportant on the controller output. The heating elements don't care. The input to the controller is important but that is not the end you are modifying.
post #3 of 4 Old 10-22-2010, 01:37 PM
Craigster's Avatar
Send a message via Skype™ to Craigster
Follow up...
I've put the OEM heated grips on my 07 650 and I'm underwhelmed by the heat they put out, particularly the clutch side. The stock bars are a very effective heat sink. Will swapping out a heat-troller for the OEM controller push any more heat out of the grips? On high the 'Zuki ones are mildly warm, certainly not "hot."
Thanks.
C
Craig Thomson
Victoria, BC, Canada
Current Ride:[b][COLOR="Orange"] 2011 Wee-Strom 650[/COLOR][/B]
Craigster is offline
post #4 of 4 Old 10-22-2010, 01:41 PM
The OEM grips themselves are the problem. Changing the controller will not help. Wiring them in parallel rather than in series will increase the heat but probably burn them out in short order.
