Vibration @ 6k RPM - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-30-2006, 11:28 AM Thread Starter
Send a message via AIM to whitelocust02
Vibration @ 6k RPM
Whenever I accel and hit the 6k RPM area (goes through to about 7k) I get a weird vibration coming from the bike. At first I thought that it was maybe my keys rattling but I rode the bike without the "Extra" keys on it and it still was happening. I have checked all the bolts and everything is fine, I'm at 1500mi and have replaced the oil 3 times so far along with the oil filter once @ 600mi. Is this noise normal with the 650's? Any ideas what could be causing it? As long as I'm not in the 6-7k rpm range the bike performs flawlessly.
Thanks for your help.
[img]http://ride4als.org/ride4als2.jpg[/img]
Chris Collins
Organizer/Rider[list][*]Motivation gets you started. Desire keeps you going.[/list]
whitelocust02 is offline
post #2 of 6 Old 07-30-2006, 01:35 PM
Two things I have found that can cause vibrations: bolt-on accessories (most notably, crash bars), and TBS being out of sync (an easy fix).
Blue DL650K5
lajaro is offline
post #3 of 6 Old 07-30-2006, 01:39 PM Thread Starter
Would you mind going into detail with the TBS sync? Is this something that the dealer I purchased the bike from should fix (ie; warranty)? Thanks!
Chris
Chris Collins
post #4 of 6 Old 07-30-2006, 04:03 PM
Dealers can take care of this, but you'd be better off doing it yourself. It isn't difficult if you're somewhat mechanically inclined (stead hand and don't have a tendency of stripping screws.
There are many postings on doing a TBS sync...a search for TBS in the forum will yield many results. Basically, it involves a few dollars in parts and about 1 hour to do the first time.
Here are some links to get you started and let you see what's involved:
https://stromtrooper.com/forum/viewto...&highlight=tbs
http://www.powerchutes.com/manometer.asp
http://72.14.207.104/search?q=cache:...ient=firefox-a
If you still have questions afterwards, feel free to let 'em rip.
Blue DL650K5
lajaro is offline
post #5 of 6 Old 07-30-2006, 05:43 PM
stromguy's Avatar
Re: Vibration @ 6k RPM
Are you referring to a vibration that you feel, or a high pitched jingling sound? If it is the sound, I hear that also sometimes... not sure what it is.
Bill
DL650K6
Pat Walsh skid plate, engine guards, oil filter guard; Givi E52 Maxia topcase with brake light, backrest and luggage rack; Amotostuff adjustable topcase mount; Givi E360 sidecases; Givi windscreen; Madstad AWM; Powermadd handguards; Fenda Extenda; Rick Mayer saddle; Suzuki centerstand, Moose Racing Quad Hi bars, Suzuki tank bra...
stromguy is offline
post #6 of 6 Old 07-30-2006, 08:28 PM
VtSTROM-K5's Avatar
Send a message via Yahoo to VtSTROM-K5
whitelocust02,
this may or may not be relevant but I had a similar
problem with a slight " Vibration" @ 5500-7000 rpm's on my '05 1K. I checked every fastener and all were spot on, So i started with wheels & tires again not the problem ?? then a friend of mine who rides a cruiser said " Ckeck your chain, jack. It sounds like a link or two may be binding". when he & I checked it sure enough three links were binding . cleaned chain w/kerosene, oiled problem links w/ P.B.Blaster penetrant, I let it soak overnite & reset the chain with a rivet link. no more vibration.
Please excuse the long post but i hope it helps.
jack
2014 V2 DL 1000 25 miles and Onward
IF I only Rode in Good weather..
I WOULDN'T get to Ride in Vermont.at ALL!
we have 2 types of roads in Vermont, Unpaved roads and decaying back to .............Unpaved roads..
2005 DL1000 98,547 miles and continuing in the hands of it's new owner
VtSTROM-K5 is offline
