cruise control? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 28 Old 05-04-2004, 04:57 PM Thread Starter
cruise control?
Has anyone installed a throttle lock or cruise control? What brands work? Specifically for the DL650, I don't know if the cables exit the same as the 1000- though I'm guessing they do.
-ted
tedder is offline
post #2 of 28 Old 05-05-2004, 12:06 PM
Bobb_Todd
I used a standard Honda Vista cruise.
Required fabrication of a tiny bracket to get it mounted solidly to the DL650. Works well.
post #3 of 28 Old 07-14-2004, 10:23 PM
yukon42
I've seen a throttlemeister ( http://rds.yahoo.com/S=2766679/K=thr...lemeister.com/) mounted on a DL1000. Should work on a 650 too. Very simple, looks good.
post #4 of 28 Old 07-15-2004, 01:18 PM Thread Starter
Throttlemeister won't work if you have factory handguards on a DL650. I used a NEP cruise control, had to attach it with Marine Goop.
Not many options if you have aftermarket heated grips and factory handguards, even if you want to spend some dough. I spent my time looking before using the goop.
-ted
tedder is offline
post #5 of 28 Old 07-20-2004, 11:57 AM
2wheeltuesday
The throttlemeister is a great unit...i became a dealer just to get them at wholesale for my buddies and I and everyone loves them. Are the 650 handguards like the bmw ones that attach at the bar end? I know mine works great on the 1000.
post #6 of 28 Old 07-20-2004, 12:15 PM Thread Starter
Yep, the DL650 handguards attach at the barend. That rules out a throttlemeister, obviously.
My wife's Bandit 600 has the TM on it. I'm not terribly impressed, but that's probably just me.
tedder is offline
post #7 of 28 Old 07-20-2004, 12:19 PM
Bobb_Todd
Although I have never owned a Throttlemeister I have used them for extended trips on other people's bikes.
I didn't like it. I had to hold the right bar with right hand and tighten with my left hand. It never seemed to hold very long before it let loose- abruptly.
I have found a cheap $25 Vistacruise throttle lock to work better for me.
post #8 of 28 Old 07-20-2004, 12:19 PM
2wheeltuesday
yeah sometimes it takes a bit of tinkering with the supplied washers to get just the desired amount of pressure on the throttle for nice steady hold. The one thing i really like it the fact there really isn't anything to wear out, fail, etc.
post #9 of 28 Old 07-26-2004, 02:59 PM
hux
I found an O-ring at Napa that fits on the inboard side on the throttle grip. It works great, but makes the resistance a bit much for around town. It cost me 39 cents. I take it off in the city.
post #10 of 28 Old 09-27-2004, 11:32 PM
Mark
Which Vista-Cruise Cruise Control model worked for your DL650? They seem to offer various models. I know the diameter is 7/8 inch, but sorry for my ignorance... not sure about dual vs. single cable throttle. Looks like the Honda Vista Cruise needed modification to fit the Vstrom. (earlier post on this string.
Rostra Electronic Cruise Control Install Instructions larolco Maintenance How-to 228 05-20-2019 12:39 PM
Rostra Cruise Control Alternate Wiring Strom Chaser V-Strom Modifications and Performance 26 07-02-2015 09:35 PM
Rostra Cruise Control Hints Ranger Ron Maintenance, Tech and Products. 8 08-06-2013 05:16 PM
Cruise control for SV650, cruise or speedometer-but not both rfulcher V-Strom Modifications and Performance 0 08-22-2010 09:22 PM
Wee-Strom with Cruise Control? Chuck in Indiana V-Curious 4 09-11-2008 09:10 AM
