Fuel Tank Removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 07-25-2006, 11:06 AM Thread Starter
Send a message via AIM to kneedrachen
Fuel Tank Removal
Installing a Healtech gear indicator today, and I STILL don't have my owner's manual from the dealership to refer to. I need to remove the fuel tank to get to the harness that allows the bike to detect whether or not it is in neutral. What's the best way to remove the tank?
Thanks,
Alex
'08 Yellow DL650
replaced
'06 Red DL650 with some goodies
kneedrachen is offline
post #2 of 11 Old 07-25-2006, 12:08 PM
PM'ed you.
Yardsale
Yardsale308 is offline
post #3 of 11 Old 07-25-2006, 01:15 PM
Please post in the forum so that more can benefit.
post #4 of 11 Old 07-25-2006, 02:16 PM
I am passing phone numbers. Not trying to hide anything, just performing OPSEC.
post #5 of 11 Old 07-25-2006, 02:24 PM Thread Starter
Yarddie- Thanks for your offer, i bought the manual today, read the post in Dealer experiences. . .
'08 Yellow DL650
replaced
post #6 of 11 Old 07-25-2006, 07:10 PM
kneedrachen
There is a downloadable version of the owners manual available in .PDF format + a ton of useful info. here:
http://motorcycleinfo.calsci.com/VStrom.html
Scroll almost to the bottom for the manuals.
Al
"If our world didn't suck - we'd all fall off!"
Anon
kamloopsal is offline
post #7 of 11 Old 07-25-2006, 08:17 PM
I followed the manual and was able to remove then reinstall the gas tank without problems. If I can do it, anybody can...
04 Blue DL650 with some add-ons
and scratches...
p7m8jg is offline
post #8 of 11 Old 07-25-2006, 11:40 PM Thread Starter
Thanks for the help gang, speed indicator should be here in the next two days, already taking pics of the job bit by bit....will post pics as soon as I am done. Once again, thanks for you help!
'08 Yellow DL650
replaced
post #9 of 11 Old 08-01-2006, 12:42 AM
Adventure Boy®
sandiegoland's Avatar
Pivot Bolt
I found it easier to remove and replace the pivot bolt at the front of the tank with the tank dropped back flat (not on the tilt bracket)
The manual implies that you remove the pivot bolt with the tank tilted, but that puts leverage on the bolt -- where dropping it back down makes the bolt slide right in or out easily (you still have to tilt before and after to make the connections)
sandiegoland is offline
post #10 of 11 Old 08-01-2006, 10:48 AM
Martin's Avatar
It's probably a bit easier getting the tank off and on if it's near-empty.
It's pretty heavy when full.
- Martin
2019 650X
Martin is offline
