Air horn - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-24-2006, 11:20 PM
dgorila1
Air horn
When adding one of the aftermarket airhorns, can you simply unplug the wires from the stock horn and use them to power the air horn or do you need to install a relay too? I didn't know if the stock horn came with a relay that would work with the aftermarket horns.
_
_
Also, when installing auxillary lights, is it best to tie them into the regular headlight or use a seperate switch to control them? How about a headlight modulator...is there one that is an easy plug in for the Strom? Thanks.
post #2 of 6 Old 07-25-2006, 03:08 AM
I think STROMETTE was the one who posted info on Stebel electric horns?
IMHO way better than airhorns.
Al
"If our world didn't suck - we'd all fall off!"
Anon
kamloopsal is offline
post #3 of 6 Old 07-25-2006, 07:47 AM
Heavy's Avatar
Serparate relay is a good idea with aux horns. Typically they draw more than the stock horn and you don't want to burn out your horn switch.
Aux lights with any sort of wattage should be switched separately and run through a relay was well. If you're just adding some LED "bling" then you could hook them into the existing.
Do a search on the modulator, there has been a fair amount of discussion and, I think, one of the suppliers is currently doing a closeout, with better pricing.
DL1000K6
Heavy is offline
post #4 of 6 Old 07-25-2006, 08:25 AM
SCraig's Avatar
Exactly right. Wattage is calculated by multiplying amps by volts. Since automotive (and motorcycle!) electrical systems run on such low voltage the amps add up rather quickly. For example, a pair of 55 watt lamps add up to 110 watts. At 13.8 volts (which is the typical voltage at which 12 volt systems operate) they will draw right at 8 amps. If you add them to the existing headlight circuit they can easily cause the switch to overheat and burn out.
The early (pre 2004) Dodge Durango has the fog light circuit switched in a really goofy manner. People were replacing the factory 25 watt fog lights with aftermarket 55 watt running lights and wondering why the headlight switch got so hot (4 amps vs. 8 amps).
Kisan carries headlight and brake light modulators. I have the brake light modulator but not the headlight. I think I got mine from CA Sport Touring but I'm not certain about that.
Scott Craig - Nashville, TN
SCraig is offline
post #5 of 6 Old 07-31-2006, 01:05 AM
STROMETTE's Avatar
Location: ON THE ROAD... (frequent stops in AZ-85338, TN-37205, CA-96150)
Here ya go for pics:
https://stromtrooper.com/forum/viewto...1172b406917f5f
https://stromtrooper.com/forum/viewto...highlight=hear
Yes on relay for horn, no on relay for headlight modulator (least not Diamond Star or Kissan).
Stromette
[B]aka "AGirl" - 2[/B][B]005 DL1000[/B]... [URL="https://www.stromtrooper.com/forums/showthread.php?t=5409&highlight=farkles+stromette"]MY STROM[/URL][COLOR=deepskyblue][FONT=Arial Narrow][COLOR=black][FONT=Arial] ...56,318 miles in 1yr of ownership[/FONT] :mrgreen: (2006 total miles on 2 wheels = 65,411) 8) [/COLOR][/FONT][/COLOR]
[FONT=Book Antiqua]* [I][FONT=Franklin Gothic Medium]Helmet laws interfere with Natural Selection[/FONT][/I]...[/FONT][B][FONT=Arial Black][COLOR=red]ATGATT![/COLOR][/FONT][/B]
[B][SIZE=4][COLOR=orange][I]:arrow: Join my journey...[/I][/COLOR][/SIZE][/B][URL="http://www.seizethejourney.com"]CLICK HERE[/URL]
STROMETTE is offline
post #6 of 6 Old 07-31-2006, 01:30 AM
rider-geek's Avatar
you definitely need the relay.
the Stebel for instance draws 24amps.
The factory horn doesn't have a relay and is switched directly through the horn button, if you attempted to run the Stebel through that, your horn wiring and switch would be fried in short order.
rider-geek is offline
