Mirror options - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 63 Old 07-22-2006, 01:34 PM Thread Starter
Mirror options
I have been trying to find good replacement mirrors but have yet to see any that I like. What I am going for is something that is lower and smaller, less in the way. I thought about maybe mounting some on the fairing but couldn't find any pics or anything to see how it looked. Anyone mount mirrors on the fairing? I have also looked at some bar end mirrors but don't know if I like those yet. Anyway, throw me some ideas and maybe some pics of what you guys have. Thanks.
2006 dl1000- grey
"A man is a success if he gets up in the morning and he gets to bed at night, and in between he does what he wants to." - Bob Dylan
"Happiness is nothing more than good health and a bad memory." -Albert Schweitzer
"What we have to learn to do, we learn by doing."- Aristotle
bigtallguy is offline
post #2 of 63 Old 07-22-2006, 08:37 PM
Heavy's Avatar
I installed a set of different mirrors today. They are almost the same width as the stock ones but considerably lower profile. They look pretty slick and they have made a marked improvement in airflow around my helmet but they vibrate pretty bad. You can still tell if there are cars behind you but you can't tell what it is.
"Was that Gramma in her Dodge Stratus, or a cop, or a moving van back there?" :lol:
DL1000K6
Heavy is offline
post #3 of 63 Old 07-23-2006, 12:14 AM
Send a message via AIM to kneedrachen
i have the OEM mirrors on my Wee, but I saw someone on here had a set of KTM Duke mirrors, definetly looked sharp. I've had bar end mirrors before on some of my bikes and they're okay as long as you don't split tight lines. I also found it took some getting used to looking by my wrist for my rearward view but got used to it over time...Definetly check out the KTM mirrors, look great!
'08 Yellow DL650
replaced
'06 Red DL650 with some goodies
kneedrachen is offline
post #4 of 63 Old 07-23-2006, 12:30 AM
allonsye's Avatar
Emgo Mirrors
I love my Emgos. They're aero dynamic, wide, have a low profile and don't vibrate.
If I recall correctly I got 'em from Dennis Kirk and only 11 bucks ea:
http://stores.nextag.com/Dennis_Kirk...oduct=87511423
You'll need p/n's 2025191 & 92. You'd better verify that. One is left the other right.
suspend reality as often as possible
allonsye is offline
post #5 of 63 Old 07-23-2006, 02:40 AM Thread Starter
Will I need new mounts or anything for the emgos? I like those the best so far and the price isn't bad either
2006 dl1000- grey
post #6 of 63 Old 07-23-2006, 09:07 AM
allonsye's Avatar
They're direct replacements - same thread size. Just call Dennis Kirk, they'll hook you up.
allonsye is offline
post #7 of 63 Old 07-23-2006, 02:51 PM Thread Starter
I ordered them from Dennis Kirk today. I will see about posting pics when I get them on. Thanks for the help!
2006 dl1000- grey
post #8 of 63 Old 07-28-2006, 01:58 AM Thread Starter
Hmmmm, don't exactly work out of the box . I think you meant to give me part numbers 2025171 and 2025172. The ones I got look almost the same so I am going to try and make them work and see what happens. The major difference is there are no threads on the bottom, just a metal tube thing that will fit a bolt through it. I plan to get the right legth of bolt and hopefully it will work and look ok enough to keep.
Any tips to keep them functional with a bolt holding them down? I want them to be tight but if I do that I won't be able to adjust them. Hmmmm, more to come......
2006 dl1000- grey
post #9 of 63 Old 08-02-2006, 06:45 PM Thread Starter
Ok, got them on.
[img][/img]
I had to finangle the bolt through the metal thing in the mirror because it was a little too small to slide through. This was the hardest part because the metal tube rotated inside the plastic preventing me from threading it easily. Finally drilled a hole through the plastic and into the metal tube, then inserted a small screw to hold the metal still while I threaded the bolt through. After that is was just a bolt on project.
[img][/img]
The bottoms are a little bigger round than the mounts but you really don't notice until you really look. I am also probably going to paint the bolts on top black to blend them in better, but they don't look that bad to me so I may leave them.
As far as function, they don't offer the big square of a view like the stockers did but they are convex so you see enough to the sides. My arms take up half of the mirror on each side but I learned to live with that on the stockers so this isn't really much of a change. There is minimal vibration when accelerating through 3-4000rpms, but that is probably when you are least likely to be looking behind you 8)
Overall I like them a lot. What I wanted was sleeker and lower profile and that's what I got. Thanks for everyones help
2006 dl1000- grey
post #10 of 63 Old 06-26-2007, 09:54 PM
$Whatever$
Heavy-H's Avatar
I don't suppose you would have the part # would you? How have they worked for you? Thanks................
06-DL1000 62000 miles....Sold...
Now 2012 Honda NC700X..37500 and counting...............FOR SALE
Now 2005 Suzuki Hayabusa..25000 and counting.......
Now 2018 Yamaha Super Tenere ES........
Heavy-H is offline
