fork mounted amber lights - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 08-24-2010, 09:57 PM Thread Starter
jonmorehouse's Avatar
^brought these home form work tonight, set of two from where i work (NAPA).
link to online supplier
4.5" diameter, they're big!
the light cluster is sealed in a round disk that screws to the cast metal housing. i'm probably going to remove it from the housing (for weight) and fabricate a mount to attach to either my fender nut or reflector nut.
these are running/turn signal lights, i'm either going to
1-hard wire the turn signal circuit to be always on, as in always bright
2- have running lights, with a bush button or rocker switch to flash or control the bright amber lights
3- have running lights, with working turn signals on the forks to flash in sync with fairing signal
it may be a few days before the install, but i'll track my progress in this thread once it comes to be. any idea's and feedback welcome. i like the metal housing they come in, but it's heavy and has a threaded base which i find difficult to mount.
jonmorehouse is offline
post #2 of 5 Old 08-24-2010, 10:20 PM
The Golden Monkey's Avatar
See this thread for ideas on getting them to function as full-brightness running lights and turn signals: https://www.stromtrooper.com/forums/s...ad.php?t=54136
If you put them on the forks, you're right to try to reduce their weight -- not only because unsprung weight is undesirable, but also because they get rattled around a lot there and the heavier they are, the harder they will be on whatever mount you come up with.
2010 Triumph Tiger 1050se
2009 DL650A - sold
2005 DL650 - dearly departed
The Golden Monkey is offline
post #3 of 5 Old 08-24-2010, 10:53 PM Thread Starter
holy smokes that thread got out of hand quick. i've had bad experiences with electronic projects of that nature. although i do know people that are capable...
post #4 of 5 Old 08-24-2010, 10:55 PM Thread Starter
also, you're fork light setup was a strong motivator for my upcoming project. i read it at work, and immediately started digging through our lighting catalog. im tired of people trying to kill me.
post #5 of 5 Old 08-25-2010, 01:08 AM
Glad to hear it! I try to give as good as I get around here, but I'm only one guy, so I'm happy if I can help anyone at all.
2009 DL650A - sold
