^brought these home form work tonight, set of two from where i work (NAPA).
link to online supplier
4.5" diameter, they're big!
the light cluster is sealed in a round disk that screws to the cast metal housing. i'm probably going to remove it from the housing (for weight) and fabricate a mount to attach to either my fender nut or reflector nut.
these are running/turn signal lights, i'm either going to
1-hard wire the turn signal circuit to be always on, as in always bright
2- have running lights, with a bush button or rocker switch to flash or control the bright amber lights
3- have running lights, with working turn signals on the forks to flash in sync with fairing signal
it may be a few days before the install, but i'll track my progress in this thread once it comes to be. any idea's and feedback welcome. i like the metal housing they come in, but it's heavy and has a threaded base which i find difficult to mount.
