EZ Helmet Hangar for your top box - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 07-19-2006, 02:06 PM Thread Starter
TomX's Avatar
1. Get a carabiner-type clippie thingy at WalMart or some such store.
2. Drill hole in topbox
3. Loop nylon cable tie around carabiner and fasten to a small washer on the inside of topbox.
- Tom
TomX is offline
post #2 of 11 Old 07-19-2006, 02:45 PM
Heavy's Avatar
I like it but I'd be concerned.
Potential for water infiltration?
Sad bounce of the helmet if the zip-tie breaks.
DL1000K6
Heavy is offline
post #3 of 11 Old 07-19-2006, 03:38 PM Thread Starter
TomX's Avatar
Never had trouble with water getting in, but I suppose you could dab a little silicon sealer stuff around the hole on the inside.
As far as the potential for helmet damage... I suppose the zip-tie could break. Although, how many times have you seen someone putting their helmet on their seat while they run into the convenience store? Talk about potential for helmet damage. Ugh!
- Tom
TomX is offline
post #4 of 11 Old 07-19-2006, 04:07 PM
Heavy's Avatar
- Tom
I know what you mean there, leaving the helmet on the seat is just too big a risk.
I'm thinking of the load on the zip-tie and long term fatigue. Maybe something like an eye bolt, with a shoulder would make me feel a little safer? They're available in stainless in all sorts of different sizes. Excellent idea, I'm always looking for a place that I can put my helmet short term (without leaving it sitting on the seat). I think I'll be hitting BRAFASCO on the way home tonight.
DL1000K6
Heavy is offline
post #5 of 11 Old 07-19-2006, 04:10 PM
Heavy's Avatar
Forgot to mention. You should add this to the "best custom farkle" thread in this forum.
DL1000K6
Heavy is offline
post #6 of 11 Old 07-19-2006, 04:57 PM
Warren's Avatar
You need a Helmet guardian:
http://www.cyclegadgets.com/Products...?Item=GUARDIAN
[B]-- Warren in San Diego --
-- 2013 KLR 650 --[/B]
-- [URL="http://www.klr650.net/forums/showthread.php?t=47348"][COLOR=blue]Click Here For My Free KLR Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
-- [URL="http://www.vstrom.info/Smf/index.php/topic,10863.0.html"][COLOR=blue]Click Here For My Free V-Strom Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
Warren is offline
post #7 of 11 Old 07-19-2006, 10:27 PM
I have been using a bicycle cable lock routed throught the rear rack and chin guard of my helmet.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #8 of 11 Old 07-20-2006, 08:59 AM
Heavy's Avatar
Hey WW, a simple and, probably, effective solution but you're going against the engineering credo:
"If it still works properly, it doesn't have enough accessories and add ons."
Why use a simple solution when you can drill holes and buy hardware? :lol:
DL1000K6
Heavy is offline
post #9 of 11 Old 07-20-2006, 11:07 AM
Actually have two bicycle locks on the Wee. They are good extensions for a couple bungees when loading a bulky whatever on board. Multi-tasking at it 's simplest and effective.
05 / 650 in blue
75/Suzuki 125 RV
post #10 of 11 Old 08-09-2006, 12:01 AM
RedAnt's Avatar
Mirrors as a helmet rack.
Perhaps this is too simple but why not just hang the helmet on your mirror? If you're riding 2-up you've even got a place for the SO's helmet!
I know it seems wrong to place it on the highest thing, but it is: solid, the correct direction to NOT fill with rain water, and about as handy as you can get (if it was any closer it would hit you in the nose). :idea:
DL650K6, MadStad adj shield, Givi e45 & e36, gpsmap 76CSx, Pat Walsh skid plate & bars, Sargent seat
2004 DRZ400S
[URL="http://www.sr.unh.edu/~rea/stromtrooper/2007/Strom_Range.png"]My 2007 Range map[/URL]
RedAnt is offline
