Electrical Tie-In - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 08-04-2010, 09:55 AM Thread Starter
Electrical Tie-In
I've seen an electrical fuse box on the web that is activated by the ignition switch. This particular fuse box mounts under the seat and has two power wires: one from the battery and another that ties in to the ignition that will activate a relay.
I'm wondering where should I tie in the relay so that it is activated by the ignition?
belvdr is offline
post #2 of 4 Old 08-04-2010, 10:24 AM
Cat Herder
LowAndSilent's Avatar
EasternBeaver makes a hit for this. Eastern Beaver - VStrom Specific - Fuse boxes
Jim has it tie into the brake light.
He also makes one for other fuse boxes, seen here: Eastern Beaver - Fuse box wiring kits. I guess you could tap into that same brake light line.
'09 VStrom DL650A - Sold.
'04 Suzuki Burgman 400 - The wifes
'08 FJR1300AE - Miss Chievous.
WWGWD?
LowAndSilent is offline
post #3 of 4 Old 08-04-2010, 11:04 AM
The trigger wire is not to the brake light but to the power wire to the brake light switch. Don't forget the ground. The fuse block needs a fused hot wire, an ignition on trigger wire and a ground wire. The brown wire to the tail light that runs in a sheath down the left side of the under seat tray can also be used for a trigger wire.
post #4 of 4 Old 08-20-2010, 02:51 PM
manshoon's Avatar
Tag for later
2007 DL1000 with allot of Farkles
manshoon is offline
