GoldWing Footpeg Mod - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 07-31-2010, 05:06 PM Thread Starter
randyo's Avatar
I was looking for a wider footpeg, but not a cleated dirtbike peg, found a couple options, Vulcan footpegs (nice, kinda trick) and Goldwing pegs, if I was going to buy them new, I woulda got the Vulcan pegs, but I got the Wing pegs free
installation was easy, the onlly mod was for the spring, the stock spring won't work, it isn't the right shape for the wing pegs, the spring from the wing peg is what you need to use, it need a 1/16"dia x 3/16" deep spring pocket drilled in the peg mount
after that, its easy
right side
left side...notice the grease fitting on the shifter, while I was down there, I've been wanting to install a grease fitting on the shifter, finally did it
I like the feel of the larger pegs, more comfortable to stand up on
I may have to lengthen the shifter though, somehting I did on my SV650, and have thought of on the Vee but it wasn't quite necessary for my big clodhopper feet, now with these pegs, I think I need to, my shifter extension mod was something I had a local fabrication shop do, cut stock shifter in half, add 1" aluminum stock and weld it all back together
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #2 of 17 Old 07-31-2010, 05:28 PM
Dorzok's Avatar
i like how you used used pegs. they don't detract from the "patina" on the brackets. Hey!! See if you can figure out what floor boards will work on the rear.
Somtimes it sucks not being in the loop. HUH??[FONT="Comic Sans MS"][SIZE="2"][COLOR="Olive"][/COLOR][/SIZE][/FONT]
Dorzok is offline
post #3 of 17 Old 07-31-2010, 11:03 PM Thread Starter
randyo's Avatar
I even cleaned the shifter when I had it off, the grease fitting is an experiment, I'm due for a new shifter, the rubber at the toe is cone shaped, linkage is getting sloppy too. 53k
with the big 1550 caribou cases, I barely have room for stock pegs for a pillon
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #4 of 17 Old 08-01-2010, 07:42 AM
JoWhee's Avatar
What a great idea, are those GL-1500 or 1800 pegs?
2003 DL 1000
JoWhee is offline
post #5 of 17 Old 08-01-2010, 08:31 AM
tmcgee's Avatar
Mine looks like yours. I have the rubber replacement and have the feeling it isn't going to be that easy to put in place.
tmcgee is offline
post #6 of 17 Old 08-01-2010, 08:46 AM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
The foot pegs off and M-50 go right on no mods.
No pics right now since they are on my buddies bike.
I put running boards on the wifes M-50, and had them laying around so figured what the hell lets try em.
Cant get em back now, buddy loves em
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #7 of 17 Old 08-01-2010, 10:23 AM
I would not bother with the shifter rubber unless it is split. I replaced mine last March and it already looks like the old one. The rubber wears down to the size of the metal end in a hurry.
post #8 of 17 Old 08-01-2010, 10:32 AM
tmcgee's Avatar
I already have it so it's going on. :mrgreen:
tmcgee is offline
post #9 of 17 Old 08-01-2010, 11:26 AM Thread Starter
randyo's Avatar
gl1500
:beatnik:
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #10 of 17 Old 08-01-2010, 12:03 PM
ozart's Avatar
Those pegs look identical to the ones on my valkyrie, which are very comfortable. Thanks for the write up.
ozart is offline
