Latest fork settings with Race Tech - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 07-24-2010, 04:36 PM Thread Starter
I hope I am not causing trouble here, especially since I rarely post. I just received my Race Tech emulators and fork springs from Blair at SV Racing. Great service, very fast shipping. After reading the instructions from Race Tech and a couple of hours on this site, my old brain is confused.
Emulators; blue spring? 1.75 turns out?
Fork oil; 10wt or 15wt?
Damper rod; 6 holes and braze the upper hole?
Springs; spacer length?
Any help would be appreciated or point me to the most sucessful thread.
I weigh 160 lbs and ride a 2004 DL 650 with 43,000 miles. I am installing an Elka on the back. Thanks in advance, John in PDX
robsonrider is offline
post #2 of 18 Old 07-25-2010, 10:43 AM
bill l's Avatar
After reading and reading I went 1 3/4 turns, 15w, 6 holes - did not braze the rebound hole shut, .95 springs where new spacer + new spring = same length as standard spacer + standard spring. I weigh 172, have Wilbers shock and 100% on-road. Both front and rear compress and rebound equally and at the same rate when I alternately sit or stand over the bike - minor miracle in my eyes! Plush ride and handles better than it has a right to.
Bill
64 Hon cub 50, 67 Hon trail 90, 68 Yam 180 twin, 66 Hon 305 dream, 71 Yam 175 enduro, 73 Yam tx500, 70 Hon sl100, 75 Hon xl250, 79 Yam sr500 , 95 Kaw en500, 98 Hon cb750, 02 Yam fz1, 06 Suz dl650, 07 Hon ST1300
Avatar:
https://www.stromtrooper.com/forums/a...4&d=1170279743
bill l is offline
post #3 of 18 Old 08-20-2010, 11:27 AM
John, if you haven't figured out your setup, I would suggest the blue spring, 1.5 turns in from first contact, 10wt oil and enough spacer to give 20 mm of preload (so that when spring and spacer sit in the fork leg and you place the fork cap on top, the underside of the cap rim is 20 mm over the top of the fork). I would follow the directions on the instructions about the holes - six near the bottom of the damper rod, leave the rebound hole as is, IIRC.
(Does anyone know where are people getting the idea to braze the rebound hole shut? What's the thinking there?)
2006 Wee rider
pak29 is offline
post #4 of 18 Old 08-20-2010, 12:14 PM
tmcgee's Avatar
It's in the RaceTech instructions.
tmcgee is offline
post #5 of 18 Old 08-25-2010, 07:52 AM
JeremyB's Avatar
I'm also very interested in this RT setup info. I just purchased a DL650 that had the gold valves and .90 springs in the forks. (I weigh 220 and don't know if this will be enough spring)
My rebound tubes do not have the small rebound hole welded shut and the valves have the yellow spring on it.
What does RT say about which spring to use on the valve body? What is the best way to determine the preload on this colored valve spring?
... BTW, sorry if this is highjacking the thread a little...:mrgreen:
JeremyB is offline
post #6 of 18 Old 09-10-2010, 01:00 PM
DrDale's Avatar
Send a message via AIM to DrDale
I just installed the RT emulators and the instructions specifically said to NOT braze over the small rebound holes.
06 DL650 w/all the goodies. Red, the fast one...
04 Honda CRF-250X
DrDale is offline
post #7 of 18 Old 09-10-2010, 02:12 PM
jokermtb's Avatar
I've not yet braised....which is probably why I've never considered getting a mod where I would have to do such a thing....
jokermtb is offline
post #8 of 18 Old 09-10-2010, 11:45 PM
rcacs's Avatar
No need to braze, you can rivet the hole shut. I can't recall off the cuff the rivet size (3/32?), but it fits perfectly.
cheers,
rcacs is offline
post #9 of 18 Old 09-11-2010, 07:51 AM
tmcgee's Avatar
They are confusing instructions, yes?
tmcgee is offline
post #10 of 18 Old 09-21-2010, 10:08 AM
Bazooka Joe's Avatar
Yes, DO plug the rebound holes. With the holes open, the rebound is too quick when the suspension is deeper in the stroke and it makes things weird. Remember, the rebound hole is actually part of the compression circuit for a fork without the emulator. (been there, done that, thought about that...)
As far as what RT says.... Getting advice from those guys is frustrating and non-productive. I'm sure from their standpoint, they'd rather not say anything so people aren't doing it wrong and get all PO'd, and maybe a legal thing, too. I installed my emulators as drop in stockers and have recalibrated substantially since. I can assure you, there is improvement to be found.
In addition to welding/plugging/brazing (I welded mine), I would suggest all this-
a) While you have the emulator out, add another bleed hole to the emulator valve plate. I added one 3/32" diameter hole and that helps a lot with the small in town sharp hits.
b) Buy the RT blue springs for the emulator ($10) and start with 1 turn of preload. Don't be afraid to go less preload- I ran with 1/4 turn before I added the extra bleed hole and it was still firm. At your weight, I would start at 1/2 turn.
c) Start with 10 wt fluid at 150mm level. (compressed fork with the emulators installed)
d) Have about 10-15mm of preload on the springs (measure how far the fork cap is away from its final installed position without compressing the spring).
e) Before you drop in the emulators, make yourself a wire hook to fish out the emulator valve in the future. SO much easier to bend it just right with the emulator in front of you, rather than guessing and trying to hook it.
Good luck with the project!
18 1000 XT yellow. Bunch of goodies installed.
2015 Yamaha WR250F- Street plated woods bike
Previous rides- about 25 different bikes, mostly dirtbikes.
Bazooka Joe is offline
