Best size lead shot to use to reduce bar vibration? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 07-18-2010, 10:02 PM Thread Starter
Hi there I'm going to try the lead shot trick to reduce the vibration in my DL650 stock bar as my hands to to sleep and it's a PITA.
So what size shot is better, smaller like #9 or larger like BB...?
Any hint/tricks I should be aware of....? Is it easier to put it in the left side or the right side or does it matter?
Can I put it in all from one side or do I have to tip the bike over both ways and pour it in?
How will I know I have enough in, when it stops running in is it full or should I "jiggle" things around a bit?
Sorry newb here :0)
Thanks!
scharfg is offline
post #2 of 14 Old 07-18-2010, 10:34 PM
janiceclanfield's Avatar
Maybe you should try some grip puppies before loading down your bike with lead weights. They're cheap, easy to install, and work quite well.
Besides, it's harder to wheelie with lead weights in your handlebars...
Sorry newb here :0)
Thanks!
janiceclanfield is offline
post #3 of 14 Old 07-18-2010, 10:35 PM
eye.surgeon's Avatar
Grip puppies will give you more relief.
'09 Wee (sold)
2012 Ducati Multistrada 1200 S Touring
2006 BMW K1200LT
eye.surgeon is offline
post #4 of 14 Old 07-20-2010, 12:18 AM Thread Starter
Thanks guys.
I put grip pupppies on my ride even before my first ride so I'm onto the next possible fix......
scharfg is offline
post #5 of 14 Old 07-20-2010, 01:18 AM
CHIA's Avatar
Maybe you need to consciously make an effort to not grip the bars sop tight?
As far as shot size, it's hit & miss, I would guess at BB size, but don;t think there's any proven formulas.
CHIA is offline
post #6 of 14 Old 07-20-2010, 02:28 AM
Lean bike over...........Which side doesn't matter.
Remove bar end weight...........
use a funnel to pour in #7 or #9 lead shot....doesn't matter what size......
Tap the handle bars with a rubber mallet or screw driver handle or use your electric razor, dremel moto-tool or whatever to vibrate the handle bars and settle the lead shot.........pack in as much as you can. You want as close to a solid mass as you can get.
Weight (mass) is your anti-vibration friend.
Grip Puppies "insulate" you from the vibration. Lead stops the vibration........both, together is nirvana!
Roy B
Massachusetts
[url]www.rvbprecision.com[/url]
2007 Suzuki DL650 V Strom abs
2007 BMW K1200R Sport abs
2004 Honda VFR abs
2001 Moto Guzzi Rosso Mandello
[url]http://public.fotki.com/Rbertalotto/[/url]
rbertalotto is offline
post #7 of 14 Old 07-20-2010, 07:43 AM
BigTom's Avatar
Go to your local Trap club and see if they have any 'reclaimed' shot for sale. Typically it's less than 1/2 the price of new, a mixture of 71/2 an 8 shot. It'll work just fine for you...
Check my Website!!
[URL="http://motorcyclebackroads.com/"]Motorcycle Backroads[/URL]
[url]http://picasaweb.google.com/tom.bigs[/url]
BigTom is offline
post #8 of 14 Old 07-25-2010, 11:33 PM
biggin''s Avatar
Maybe need to do a TBS? I've only ridden a 650 once but it was smoother than my
1000, as far as vibes go. anyway, it was just a thought. good luck.
biggin' is offline
post #9 of 14 Old 07-26-2010, 09:43 PM Thread Starter
Awesome stuff thanks guys, I tried to purchase some lead shot from a gun store but the plant in Winnepeg shut down so they can't get any, plus we only can use steel shot in CND now for migratory birds. I have some old #5+6 shot shells lying around from when we could use lead on ducks so I'll cut them open and pour that in. I imagine a box (25x 10z/shot) should be enough.
Good idea about the vibration as well, will give it a go as well.
Take care and THANKS!
scharfg is offline
post #10 of 14 Old 07-26-2010, 09:58 PM
MrHaun's Avatar
One box of shells isn't going to cut it. You will only get around 25oz of shot out of that box. That might sound like a lot, but it isn't. I am guessing you will need something closer to ten pounds of shot. I do my own reloading for skeet and a 25 pound bag of shot is a lot smaller than you would think.
I would take the advice of going to a trap or skeet club. They have to have the lead reclaimed every so often to minimize the leeching into the ground water. You should be able to get some from them one way or another.
MrHaun
"Barry, you know making a plan is the worst thing you can do when you are traveling." Malcolm Rose - RIP
2008 DL650 Yellow
[COLOR="Gray"]2000 HD 883 XLH - Sold[/COLOR]
MrHaun is offline
