Handlebars with less bend? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 07-09-2006, 11:24 AM Thread Starter
Hi, I'm looking bars with less inward bend at the grips for a more natural wrist angle.
And I'd like to find something that doesn't require new cables.
Suggestions?
-dennis
2006 DL650 Silver Blue
2004 Triumph Thruxton
d2mini is offline
post #2 of 17 Old 07-09-2006, 12:30 PM
Heavy's Avatar
I'm sure some use of the search function will result in an answer to your question. Just look for something with similar rise and width with the reduced angle.
DL1000K6
Heavy is offline
post #3 of 17 Old 07-09-2006, 01:01 PM Thread Starter
Maybe I used the wrong words in my search beause that didn't help, hence my question to the forum.
-dennis
d2mini is offline
post #4 of 17 Old 07-09-2006, 01:24 PM
I'm using Pastrana FMX Protapers which are very "flat" with very little bend back towards the rider. But you'll need adapters to mount them. Do a search on "Protapers" and you'll find a thread with pictures.
A bunch of us have posted here (and on the other big Strom forum) about handlebars, so the info is here if you look for it.
- Mark
markjenn is offline
post #5 of 17 Old 07-09-2006, 01:41 PM
kurt1305
Pro-Taper SE ATV Mid bend bars. Lots of posts about them, I tried a different bend first, but these are perfect. They mount with no modifications to cables, clamps or anything else.
post #6 of 17 Old 07-09-2006, 02:04 PM Thread Starter
Protapers... ok cool. I'll check those two.
I also found some mention of Speigler bars? Will they give a straighter wrist position?
-dennis
d2mini is offline
post #7 of 17 Old 07-09-2006, 02:12 PM
kurt1305
If you get them, contact me and I'll give you a couple of installation tips.
post #8 of 17 Old 07-09-2006, 09:46 PM
I've got a set of aluminum Answer CR High bend bars.. One of these days, I'll actually put them on.. :lol:
humbug
Paper is offline
post #9 of 17 Old 07-09-2006, 11:48 PM
boatvs's Avatar
http://11109.rapidforum.com/topic=111075011859
Bill Eakins
Butler Maps & Rever - motorcycle maps & app for riders by riders
http://www.butlermaps.com/
http://www.rever.co/
boatvs is offline
post #10 of 17 Old 07-10-2006, 12:47 AM
boatvs's Avatar
pro taper se atv-md has a pull back of 3" (5.9" height) . atv-hi is 3.94" (6.3" height) . pullback is much better than stock and the bar angles up. for comparison the pro taper cr-hi (which may consider one of the best overall dirtbike bends for comfort) pull back is 2.45". so the atv-mid has a more forable and closer to natural bend than the atv-hi. comfort level depends on your arm legnth. you might need an up and back riser (with possiblly longer lines). another option is to use the cr-hi and use the $20 adjustable up adapter: http://www.rockymountainatv.com/prod...1&navType=type to find your perfect height. the riser plates could also be used with the genmar (but not the motech) up and back riser to adjust height also. just remeber less pullback equals more forward lean and the protapper are aluminum bars so ore work is needed to get barends/handgaurds to fit. msr and moose make steel bars (poosibly the same mfg) but watch the numbers as the same atv-hi description has different dimension depending on mfg. rocky mountain atv printer catlog has great reference number which i use to reference this. thaey carry protapper and msr steel but no moose.
Bill Eakins
boatvs is offline
