Raising fork tutorial? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 21 Old 06-05-2010, 11:20 PM Thread Starter
CoastalDefender's Avatar
Is there one?
I'm a total newb to it and for the longest time I was under the impression it had to do with the pre-load on top of the triangle.
However, after reading a bunch on it (I am squirrely in my front end), It occurs to me that I was under the wrong impression of what the procedure really is.
So my total newb question is, is there a tutorial, with pics, for people like me who don't have a damn clue what they are doing, but are decent with a wrench?
I just don't want to F this all up is all.
[SIZE="2"]Meat is Murder.[/SIZE]
[SIZE="1"]Tasty, tasty murder...[/SIZE]
CoastalDefender is offline
post #2 of 21 Old 06-05-2010, 11:58 PM Thread Starter
Uhh, NM. I used my eyes, brain, and mechanical ability. Not to mention a measuring tape, and a 10mm wrench...
post #3 of 21 Old 07-31-2010, 08:57 AM
Fellow Traveller's Avatar
For those who still want fork raising tutorial...
There should be some info on the site regarding the process.
Here's a hint for people searching for something on any particular website. Go to google, type "site:" into the search box, immediately followed by the name of the website you want to search, then a space, then type in the keywords. Google will then search only that website for your keywords. Your search on stromtrooper.com for fork raising might look like this, for example:
site:stromtrooper.com raise forks raising forks
In any case, raising the forks is easy. You simply rig up the bike so that the front end can't sag (a center stand is a good starting point), then loosen the clamps that hold the left and right fork in place, then move the fork shafts up in the clamp and re-tighten. Exactly how you raise them, or conversely let the bike sag down and therefore slide the forks upward through the clamps, is up to you. Raising them about 15 mm seems to be the sweet spot.
HOWEVER, if your front end is squirrely, as you say, I would check a lot of other things first.
1. Is the bike squirrely when riding a particular patch of road, such as one with a lot of grooves or cracks in it, or rain grooving? If so, there's nothing wrong with the front end of your bike, that's normal.
2. Next things to check, in this order: wrong tires, worn out tires, wrong tire pressure, incorrect preload on front or rear shocks for your weight, too much weight in rear, something loose with the steering bearings, something wrong or altered with shocks.
If it's none of those things, or you still have a problem after adjusting all of those things, then you may be very sensitive to steering issues, in which case you might want to install a Superbrace or Ricks fork brace, which will tighten up the front end, noticeably for most people.
But I wouldn't start off jacking with raising or lowering the forks. Suzuki engineers know what they're doing, and messing with the steering geometry should only be done when you have enough miles on the bike to know what you're looking for in the fork adjustment, because it will change the way your bike handles under different circumstances, and you want to be sure that's the change you're after.
Last edited by Fellow Traveller; 07-31-2010 at 09:56 AM. Reason: incorrect heading
Fellow Traveller is offline
post #4 of 21 Old 07-31-2010, 09:39 AM
Do the left and right separately. One side will hold the bike up while the other side is adjusted. It's way simpler than propping up the front of the bike to the correct height. Loosen both sides without otherwise supporting the front and the triple clamp can drop to the fork seals.
post #5 of 21 Old 07-31-2010, 09:48 AM
Good point
...about doing one side at a time. I actually thought about that after posting, but figured that anyone adjusting the forks would see that if they didn't support the front end, or didn't do one at a time, then depending on how your were set up, the forks would slide in or out excessively.
post #6 of 21 Old 07-31-2010, 11:40 AM
Put the bike on its centerstand. Put a floor jack under the front exhaust pipe and barely lift the front wheel off the floor. Loosen the three bolts on each side that hold the fork tubes in the triple trees. Let the jack down a twitchet while bashing the top triple tree with a rubber hammer. When you go more than 15 mm, jack up the front and move the forks back down to the 12~15 mm range. Tighten the clamping bolts. You're done. On an ABS bike, be sure the distribution block between the forks can not contact the lower triple tree at full compression.
post #7 of 21 Old 07-31-2010, 12:10 PM
That is a lot more work than necessary.
post #8 of 21 Old 07-31-2010, 10:37 PM
More work... or not.
The original post got me thinking about raising the forks in my bike again. Although I have no beef with the steering on my 09 DL1000, it is a fact that, at relatively high speeds, or going into a strong wind and highway speeds, I always had the gut feeling that the front wheel was a bit light. That is, that it needed more downward push. Some downward push is provided by my Givi windshield, I'm sure, since I have it raked back at about a 45 degree angle. Still, I've often moved as far forward as possible on the seat and leaned over whenever I got that gut feeling that the front wheel wasn't planted. Again, no real evidence, just a feeling.
So, spurred on by this thread, I raised the forks about 1/2" (12 mm) from their OEM position this morning and rode the bike about 175 miles today, making a huge loop from Hemet to Banning up through twisting mountain roads to mile-high Idyllwild, down to Palm Desert, through the broiling heat to Palm Springs, through San Gorgonio Pass (that's the place you see in movies with about 10,000 gigantic wind turbines) into a 45 mph headwind while going 75 indicated, back to Banning and home. Took side tours on dirt and old asphalt for the hell of it.
Two things:
1. If you have a fork brace on your bike, you can't -- I couldn't-- move one side of the fork at a time more than a slight amount. You have to loosen both simultaneously and move both simultaneously. It was still easy -- I just stacked some lumber beneath the skid plate to about the right height, loosened all clamps most of the way, then tapped on the triple tree until I got what I was looking for, then tightened it all up.
2. I think raising the forks makes a difference. The bike tracked around corners pretty well when I first got it, tracked even better when I put the Superbrace on, and now it just seems like it's on rails at high speed, and even seems better at lower speeds on grooved pavement, cracked pavement, and tar-snaked pavement, all of which I rode over today.
Could it be my imagination? I don't think so.
post #9 of 21 Old 07-31-2010, 11:22 PM
I have a fork brace and move one side at a time. The previously mentioned rubber mallet comes in handy.
post #10 of 21 Old 08-01-2010, 09:01 AM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
Question?????????
I have thought about lowering the front on my DL1000 since as stated here it feels light especially around big trucks and wind.
Would just lifting the back 5/8" give the same results?
I'm concerned about lowering a bike that I might take on a dirt road.
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
