Couple of mods today - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 1 Old 05-31-2010, 07:41 PM Thread Starter
Well, after working from home for a bit, I logged off and played with the strom. I lowered the front end 1/2" (12.57mm for you metric folks), added a 2" powermadd riser, and installed the eastern beaver wiring kit for the brake light on my trunk.
I didn't realize I'd have to take off the grab bar/trunk mount and mounting plate to get to where the plugs were so while I had the plate off, I cut two holes in it so that I can put on or remove the grab bars/trunk mount without taking off the trunk plate. That also meant that I could put the plate on with the grab bars off of the bike which made it so much easier!
The riser took a bit of work since I had to move the clamp for the brake line so that I had enough slack. I also had to retie some of the cables so that they had slack as well.
Overalll I'm pleased with everything. I was plesantly surprised that the stock shield on the madstad bracket is still sufficient even with the riser in place.
mikeg
K5 Wee (Blue)
mikeg is offline
