fuel tank quick disconnect - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-29-2010, 07:44 PM Thread Starter
mkporwit's Avatar
Didn't find anything on this site searching via google, so apologies if this has been covered somewhere already...
Does anyone have any recommendations for a fuel tank quick disconnect for the Wee? I found these, which look built like a brick outhouse... what diameter is the Wee's fuel line?
Marcin
2009 DL650A
2008 TE610
mkporwit is offline
post #2 of 7 Old 06-01-2010, 07:00 PM
lefty80883's Avatar
I believe your bike already has one. My '07 does. The owners manual may cover it. The service manual must surely cover it. I've had my tank off a few times and it isn't too difficult.
lefty80883 is offline
post #3 of 7 Old 06-01-2010, 07:17 PM
Cat Herder
LowAndSilent's Avatar
Oh Marcin...what are you up to now? :biggrinjester:
'09 VStrom DL650A - Sold.
'04 Suzuki Burgman 400 - The wifes
'08 FJR1300AE - Miss Chievous.
WWGWD?
LowAndSilent is offline
post #4 of 7 Old 06-01-2010, 07:20 PM
K1W1's Avatar
That's correct.
Lift the tank and squeeze the little doohicky to release the fuel line. The hard part is making sure it's seated correctly when you push it back on. If it's not fuel starts leaking down onto the back of the motor.
K1W1 is offline
post #5 of 7 Old 06-02-2010, 08:42 PM Thread Starter
mkporwit's Avatar
Adam -- nothing good
Actually, right now I'm mainly doing brakes and suspension. New front suspension and Tokico 4-pot calipers early next week, then an Ohlins shock for the rear sometime in early July
Marcin
2009 DL650A
2008 TE610
mkporwit is offline
post #6 of 7 Old 06-02-2010, 09:54 PM
silverstrom's Avatar
There are only 3 things to disconnect to remove the tank. The vent, the electrical connector, the fuel line quick disconnect. :mrgreen:
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #7 of 7 Old 06-02-2010, 10:17 PM
It depends on the model. That vent is actually the drain from the gas cap well. Tanks on bikes with charcoal canisters also have an actual vent hose rather than a vented gas cap.
