Scottoiler Automatic chain lubrication system??????? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 37 Old 07-04-2006, 11:41 AM
Grim
Does anyone have or has anyone fitted one of these devices?
If so was it easy to fit?
And did you use the universal kit or is there a specific kit that is better than the rest for the Strom?
Finally if you fitted one would you go for the extra expense of the dual feed injector?
http://www.scottoiler.com
I'm tempted by this bit of kit but before I spend my money i'd like to know if its loved or loathed?
post #2 of 37 Old 07-04-2006, 11:49 AM
I've had a scottoiler on my GS1200 since new. It gave me 26000 km on the chain and sprockets, and would have ben a lot more except for a mistake I made which stretched one section of the chain.
I have ordered a new one to be supplied with my new K6.
I had the last one installed by the Suzuki stealership, but they made such a poor job of the installation that I had to redo it myself. I shall carry out the entire installation myself for this one.
Jantar is offline
post #3 of 37 Old 07-04-2006, 02:54 PM
Vstromper's Avatar
I haven't bought one yet (I'm poor) but you might want to check this out first:
http://www.pro-oiler.com/
That's the one I'm going to get... eventually.
Peace carries a big gun!
www.k-diggityrides.blogspot.com
'04 1k Blue
Vstromper is offline
post #4 of 37 Old 07-04-2006, 03:28 PM
Heavy's Avatar
Don't listen to Vstromper, get a Loobman!
http://www.chainoiler.co.uk/
Not expensive and very simple.
DL1000K6
Heavy is offline
post #5 of 37 Old 07-04-2006, 08:49 PM
Vstromper's Avatar
Just to calrify, I didn't say or mean to imply "don't buy this. Buy that." I don't have any personal experience with any chain lube system so I will defer to others.
I just thought you might want to check it out so you know what other options you have. By all means check out the Loobman as well and buy the one that best suits your needs and budget.
The thing I like about the Pro-oiler is that it is automated according to mileage rather than time and it is fully adjustable while riding. You can turn it up if you go through a rain storm or turn it off if you're stuck in a traffic jam so you don't soak your tire. And you can do it all without stopping. Is it worth 10 times as much as a Loobman? That's your call.
The Scottoiler can only be adjusted at stops and will continue to drip oil as long as the engine is running, whether the bike is moving or not. And it will drop the same amount of oil on the chain in a given time period regardless of speed.
The Loobman is manually operated but should (according to their website) only be charged at stops and the bottle has to be mounted within reach.
Like I say, these conclusions are from published literature not from personal experience so feel free to correct me if I am wrong.
'04 1k Blue
post #6 of 37 Old 07-04-2006, 11:28 PM
Night_Wolf's Avatar
This is what I'm using and I'm a shade over 38,000km so far or 23,000+ miles. Cheap and it works
Type @ Ya'll Later
Night_Wolf
2007 DL650abs Wee Strom
VSRI 1083/MIG 2625
A Newfie & Damm Proud Of It
Night_Wolf is offline
post #7 of 37 Old 07-05-2006, 04:26 AM
I had a Loobman about five years ago, couldn't get on with it. I also found the build quality lacking.
On the new Strom I've got a Scottoiler, which I had fitted by the dealer when I bought the bike. Too early to comment on the usability yet but the installation is good.
Dr Gonzo is offline
post #8 of 37 Old 07-05-2006, 07:44 AM
wingman's Avatar
I'll second the vote for Loobman. Its a cheap alternative but works well for me.
Wingman
2001 GL1800 Blue
2005 DL650 Red
wingman is offline
post #9 of 37 Old 07-05-2006, 10:15 AM
Heavy's Avatar
Originally Posted by Vstromper
Just to calrify,...so feel free to correct me if I am wrong.
Hey Vstromper, my post was supposed to be taken with a smile, a large smile. I meant no harm by it. I've never used either system before so I'm not talking from experience. I did just order a Loobman recently. I figure, for the few bucks it cost I can't go wrong. Even if I only learn that I hate it.
DL1000K6
Heavy is offline
post #10 of 37 Old 07-05-2006, 10:56 AM
What I don't understand is why get one of these when other people don't even lube there chains with anything other than Wd-40. Is there any facts out there as to whether or not we need to be this anal with chain lubrication on todays sealed o-ring chains?
I've been using a chain wax myself so far.
-dennis
2006 DL650 Silver Blue
2004 Triumph Thruxton
d2mini is offline
