Admore Lighting Givi V35 Install - Help! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-24-2010, 11:58 PM Thread Starter
I installed the Admore LED kit in my Givi V35 bags on my ABS Wee this weekend. I drilled the connector hole with the bags off the bike, and when I installed the racks and went to put the right side bag on, I found the exhaust heat shield is interfering with the connector. I don't think I have enough cable to run the connector far enough down that it won't hit the heat shield. Admore says lots of V-Strom owners have used these, so it sounds like it must be operator error. Can anyone who has this kit give me some guidance, with some photos if possible?
Thanks in advance.
swingle12 is offline
post #2 of 3 Old 05-25-2010, 09:09 AM
LesHeight's Avatar
Send a message via MSN to LesHeight
I had the same problem and had to re-drill the right side bag to position the connector a bit higher. You are right that going low enough to clear the muffler will run you out of wire.
If you email Admore they will send you a set of plugs that will fill the first hole perfectly (see the second picture).
Good luck,
LesHeight
2009 DL650 127k and counting
2015 DL650XT
Time you enjoy wasting was not wasted.
- John Lennon
LesHeight is offline
post #3 of 3 Old 05-26-2010, 01:46 AM Thread Starter
Thanks! That's exactly what I needed. I guess I should have done the re-assembly before I drilled. Looks like I'll be needing one of those plugs! It's a nice kit, but I do wish they'd included enough cable to route it below the exhaust.
