Speedo correction by repositioning indicator needle? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 06-27-2006, 10:09 AM Thread Starter
Martin's Avatar
It occurred to me the other day that *maybe* it's possible to correct the high-reading speedo's by removing the cover of the speedometer, pulling the speedo needle off and re-positioning it so that it reads more correctly. I have no idea how the speedo cover comes off though.
Anybody care to give it a try? :wink:
- Martin
2019 650X
Martin is offline
post #2 of 6 Old 06-27-2006, 01:42 PM
it's a 8-9% error across the board, not a 5mph error. even if you could make a correction for one speed, it would be wrong for the others. i think it may recalibrate the needle position every startup though. a speedo healer would do a much better job.
post #3 of 6 Old 06-27-2006, 03:24 PM Thread Starter
Martin's Avatar
I thought it sounded too simple to be true.
- Martin
2019 650X
Martin is offline
post #4 of 6 Old 06-27-2006, 05:25 PM
Night_Wolf's Avatar
I found the Avon Venom X 100/110/19 helped "correct the 10% erro to a 5% error. To be fair the ME800 of the same size performed the same correction on my Wee Strom
Type @ Ya'll Later
Night_Wolf
2007 DL650abs Wee Strom
VSRI 1083/MIG 2625
A Newfie & Damm Proud Of It
Night_Wolf is offline
post #5 of 6 Old 06-29-2006, 12:48 PM
I agree, with the GPS on I notice the faster I go the bigger the gap.
5 mph or so off at 40-45 mph
7-8 mph or so off at 75-80 mph
That said, I have no idea how to correct it..
Good luck,
DavidLSI
3 miles on p/u 4/22/06 55,700 as of 6/14/09 and climbing..
DavidLSI is offline
post #6 of 6 Old 06-29-2006, 01:29 PM
Heavy's Avatar
Should take you a long way to correcting your error.
http://www.speedohealer.com/
DL1000K6
Heavy is offline
