Illuminated Toggle Wiring Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 04-24-2010, 07:03 PM Thread Starter
r1madman's Avatar
Want to replace the standard three pos toggle that came with my Trackside heaters with an illuminated toggle that I picked up (marine quality) but have a question... the Trackside toggle is a three blade (one lead from resistor side of pigtail, combined leads from both grips, one lead from relay/battery) but the Seasense Illuminated toggle is a five blade connection; 2 additional blades marked "Internal Light Positive" with the other three as Ground, and 2 switched positives... how the frick do I wire this up??? Any help is GREATLY appreciated, and thanks in advance
P.S.- Before the Search First Nazis jump in, I did search and even google:stromtrooper searched and had no luck...so there!
Strom Squadron Member #6
Silver Strom Club #29
r1madman is offline
post #2 of 4 Old 04-28-2010, 10:32 PM Thread Starter
r1madman's Avatar
Anyone??? No one has any helpful insights???
r1madman is offline
post #3 of 4 Old 04-28-2010, 10:41 PM
jonmorehouse's Avatar
you need to supply 12v power for the lights to the two mystery blades.
jonmorehouse is offline
post #4 of 4 Old 04-29-2010, 01:12 PM
ozart's Avatar
Hard to tell from your description. Did the new switch not come with any wiring instructions? A little more info would help, especialy if you can provide a link to the exact switch you're talking about?
ozart is offline
