An amazing motorcycle... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 66 Old 06-25-2006, 08:38 AM Thread Starter
Heavy's Avatar
Sorry to those of you looking for some super exclusive exotic, its my 2006 DL1000. In its defense, read the story that follows.
This bike has been transformed, it is pure joy to ride. More responsive, smoother, more versatile. It is amazing!
I finally decided I would take the time for some maintenance and to install some accumulted farkles. In terms of performance, I did the following:
1.) Discovered the boot from the air box was not even attached to the front throttle body. Replaced the stripped screw on the clamp and installed the boot properly.
2.) Installed a K&N air filter.
3.) Installed extension hoses to simplify throttle body synchs, and did a synch.
4.) Removed secondary throttle butterflies.
5.) Adjusted throttle cables.
5.) Installed 43T rear sprocket.
Since I did everything at once I canít comment on individual improvements but I can tell you that the sum of my efforts is awesome. The thing now pulls like a freight train, 6th is a completely functional gear and it runs smoother at all speeds than it used to. I love it! I went for a ride yesterday and every time I twisted the throttle I grinned like an idiot.
Removal of the secondarys has made the throttle much more responsive. I felt the stock setup had too much lag to it and it was imprecise. Now, it is instantaneous and crisp. I find it much easier to match engine speed to bike speed for butter smooth shifts, up or down.
The 43T sprocket lowered the gearing enough that it is completely useable at sensible highway speeds. The bike cruises nicely in the 100 Ė 110 kph (65 Ė 70 mph ) range now, and doesnít feel like its lugging. Running up through the gears is a riot and the bike just rockets ahead, gaining speed at an amazing rate.
I liked this bike a lot from the day I bought it but I did have some issues with how the engine ran and I knew the gearing was not right for me. These relatively simple and relatively inexpensive changes have transformed the bike. Now I simply love it. I canít think of a more capable, versatile machine. Head out and blast back roads, explore that quiet gravel route or snap on my Givi bags and head out on the highway for a week, this V-Strom thing will do it all and do it well.
Other add-ons included a Blue Seas aux fuse box, Stebel compact air horn (to be the first accessory for any new bike in the future) and a Speedo-Healer.
DL1000K6
Heavy is offline
post #2 of 66 Old 06-25-2006, 10:11 PM
Nice write up.
Where did you get the screen? That is what I am looking for?
Motorcycle riding elementary school principal
2005 DL1000, black of course, heated grips, throttle lock, centerstand, Dobeck Techlusion box, more to come!
KTM XCW300 for the dirt
Littledog is offline
post #3 of 66 Old 06-25-2006, 11:27 PM Thread Starter
Heavy's Avatar
I actually wrote about it in a reply to one of your posts. Its a stock screen with 3-1/2 inches cut off the top and painted black. Cheap and easy.
DL1000K6
Heavy is offline
post #4 of 66 Old 06-26-2006, 12:52 AM
So now Heavy can rave about his girlie bike even more. lol. Good to hear the bike runs well without a lot of messin around and expense.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #5 of 66 Old 06-26-2006, 01:04 AM
Is there any good step by step instructions for removing the 'secondaries'? I would like to do this but am not sure how to get to it...
Thanks,
B
05' Vulcan 1500 Classic Galaxy Silver
06' V-Strom DL1000 Gray
BrianG is offline
post #6 of 66 Old 06-26-2006, 01:33 AM
Thanks,
B
Take off your fuel tank and pull out your air cleaner. Look down and you will see down into the intake and the secondaries will be staring you in the face. On the secondaries each will have 2 phillips head screws. Take out the screws and pull out the secondarys. Do not drop the screws into the intake and leave them. Then put it all back together.
ekaphoto is offline
post #7 of 66 Old 06-26-2006, 08:35 AM Thread Starter
Heavy's Avatar
Simple as that. Only thing that makes it a little less scary is to rub the screwdriver shaft with a magnet before you start unscrewing the phillips screws. You will magnetize the screwdriver and reduce the chance of dropping the screws into the intake.
DL1000K6
Heavy is offline
post #8 of 66 Old 06-26-2006, 08:37 AM Thread Starter
Heavy's Avatar
'Dis ain't no girlie bike no more. It'd kick your little Wee-wee's ass!
DL1000K6
Heavy is offline
post #9 of 66 Old 06-26-2006, 09:01 AM
Did I read correctly ? You say "no more" Then it was and you admit it.
05 / 650 in blue
75/Suzuki 125 RV
post #10 of 66 Old 06-26-2006, 09:26 AM Thread Starter
Heavy's Avatar
Just trying to maintain continuity in your skewed view of the situation.
The reality is that it was a Man's Bike from day 1. Now its a Serious Man's Bike.
Just ask stromette, she's done the same mods to hers.
Aren't you supposed to be working or resting up to work or something like that? :wink:
DL1000K6
Heavy is offline
