Raising forks - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 54 Old 04-12-2010, 07:21 PM Thread Starter
Raising forks
First off let me appologize for not searching harder. I'm at work on my iphone and want to do this after work.
I'm wondering what the proper torque is for the forks when i raise themin the clamps. Any help would be appreciated. Also, 15mm is the prefered amount, correct?
SoCalTech is offline
post #2 of 54 Old 04-12-2010, 07:44 PM
Loosen the upper and lower clamps on one side, slide the fork tube up and tighten it back up. Then do the other side. That way the bike is supported by one tube at all times.
DL650A K7
StromTech is offline
post #3 of 54 Old 04-12-2010, 07:49 PM
SCraig's Avatar
16.5 ft/lb. 15mm is what I run. They will go to about 20 before hitting the handlebars but I didn't like it there and went back to 15mm.
Scott Craig - Nashville, TN
SCraig is offline
post #4 of 54 Old 04-12-2010, 08:19 PM
What Kinda Bike Is That?
Black Lab's Avatar
For some reason, that method doesn't sit right with me. I am not saying it is wrong and doesn't work, it's just that there is some "torquing" to the front end to get that to work.
IMPORTANT ADDED NOTE:
When torquing the four, (two per fork tube), lower fork clamp bolts, DON'T just torque one of the bolts and then the other and think you are done; you are not!!!
You MUST torque one of the bolts first, then it's "brother" next to it, then go BACK and retorque the first bolt again.........then double check the second bolt.
If you just torque, say, the upper bolt of the lower fork clamp, then the bottom bolt of the lower fork clamp and think you are done, you are wrong. By torquing the lower bolt, the upper one becomes loose again.
Go back and forth between these lower fork clamp bolts, torquing them and retorquing them to ensure they are truly tight.
B.
Black Lab is offline
post #5 of 54 Old 04-12-2010, 08:42 PM
Worked for me one side at a time when I did it last fall. I just checked them again this spring as part of my get ready for the road routine and they were all still OK. But it would not hurt to recheck the torque after you have both sides done.
DL650A K7
post #6 of 54 Old 04-12-2010, 09:35 PM
I've always done it that way.
post #7 of 54 Old 04-12-2010, 09:44 PM Thread Starter
Ok, got that done. Now I'm trying to bleed the front brakes after replacing the line so i can install my risers. Fun night...
Thanks for the help everyone.
post #8 of 54 Old 04-12-2010, 10:37 PM
Be very patient. Blair suggests tying the brake lever down overnight to allow more air to work its way out.
post #9 of 54 Old 04-12-2010, 10:42 PM Thread Starter
Ill have to try that once i get home. Thanks for the info.
post #10 of 54 Old 04-13-2010, 09:05 AM
Braveheart's Avatar
Front fork modification
I would like to try this modification too. I already have a Murphs fork brace installed. Would I have to remove this to drop the front forks by 15mm or is it possible to do this without removing it and then re-installing it ?
[B]'08 [COLOR="Navy"]BLUE[/COLOR] DL650A K7[/B]
[COLOR="Navy"]Suzuki Handguards, Sport Windscreen, Centre Stand and Gel Seat, Pyramid Fenda Extenda, Givi Maxia E52 Top Case on Givi E200 mounting bracket, Givi E21 Side Cases on Givi PL532 Side Racks, Hyde Racing Skid Plate, SV Racing Parts Sliders, Madstad Windscreen Bracket, Richland Rick's Mirror Extenders, K B Fork Brace, Migsel GPS Mount, Garmin Zumo 550, SW Motech Bags Connection Quicklock City Tank Bag, Alaska Leather Sheepskin Delux Buttpad, Grip Puppies.[/COLOR]
Braveheart is offline
