Extended shift lever - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 04-10-2010, 08:42 PM Thread Starter
Following posted recommendations swapped out the OEM shift lever/ linkage with a DR650 replacement lever. Believe it was an MSR for approximately $25.00. Works great for a size 12. :mod_biggrin:
Illinois is offline
post #2 of 5 Old 04-10-2010, 10:30 PM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
Nice info, where did you order it from?
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is online now
post #3 of 5 Old 04-10-2010, 11:05 PM Thread Starter
Mike
Mike- Believe it came from Bikebandit. Be advised that I have a Vee. From what I've read on this board it would somehow change the shifting pattern on the Wee. You might try a "search" for more accurate information. :-D
Illinois is offline
post #4 of 5 Old 04-10-2010, 11:43 PM
I kinda figured your must be a Vee when I went looking for the part.
Wish they would come up with an extended for the Wee
Mike
Las Vegas, NV
post #5 of 5 Old 05-20-2010, 08:47 PM
fredellarby's Avatar
I bought a steel replacement for my 650. I'm going to have a 1.5" piece welded into the middle.
Fred
I'm not always sarcastic.
Sometimes I'm facetious.
Or ironic.....
If a tree falls in a forest and lands on a politician, even if you can't hear the tree or the screams, I'll bet you'd at least hear the applause.
Paul Tindale
fredellarby is offline
