LED light strips - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 01-31-2010, 09:04 PM Thread Starter
andreas's Avatar
LED light strips
I decided to play with the luggage, good thing they are only the JC Whitney cases, don't think I would have done this with $1k luggage.
This is what I had before I began
First I dremmeled the ribs a tad wider, had to drill a hole for the wire's as well, two strips per case. One was for the signals, the other for brake lights. Colors are according.
Here I did a dry try before I applied the epoxy.
Finally I epoxy'd the strips, then I found my signal wires and cleaned the plastic off, soldered wire to those, then hot-glued the wires to protect them again.
Making my own 3 prong plug's I am able to unplug the cases if I want to remove then.
I took a video with my cheapo Fuji camera, blinkers and brake lights all work awesome. The auxilory brake lights on the luggage are connect to the 'Back-off' unit. they now blink 5 times - hold for 5 sec's then blink again. Hope it can be opened.
http://s675.photobucket.com/albums/v...rksworking.flv
FB MEMBER #133 - 2008 Wee
andreas is offline
post #2 of 19 Old 01-31-2010, 09:32 PM
What Kinda Bike Is That?
Black Lab's Avatar
Really nice work!!! Very visible and very sensible implementation.
B.
Black Lab is offline
post #3 of 19 Old 01-31-2010, 10:14 PM
Cat Herder
LowAndSilent's Avatar
I agree...that really is some great work!
Excellent job on the install.
'09 VStrom DL650A - Sold.
'04 Suzuki Burgman 400 - The wifes
'08 FJR1300AE - Miss Chievous.
WWGWD?
LowAndSilent is offline
post #4 of 19 Old 01-31-2010, 10:38 PM
maggot's Avatar
Results look good. Couldn't you have put the strips under the red plastic lens without needing to cut anything??
Ken
2007 DL650 Gray
maggot is offline
post #5 of 19 Old 02-01-2010, 05:40 AM
Impressive results. A big WELL DONE.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #6 of 19 Old 02-01-2010, 07:55 AM Thread Starter
andreas's Avatar
Ken
Thanks for the compliments Everybody !!!
Maggot The red / orange material is not see thru, and the space available was not big enough. I was trying to look at other options first because I knew if I screw this dremmel job up there's no going back. The dremmel made it just right, I did shave a little much sometimes, could see the hollow space of a raised rib, but the light strip and epoxy covered that.
My mistake was not painting the plastic prior to glueing the strips in - next time I guess.
andreas is offline
post #7 of 19 Old 02-01-2010, 08:46 PM
maggot's Avatar
Well that makes sense..
I have 6 strips, identical to yours ( but 24cm) on the way that I got on fleabay last week. I'm gonna put them inside the lenses of my givi trunk.
Ken
2007 DL650 Gray
maggot is offline
post #8 of 19 Old 02-02-2010, 08:52 AM Thread Starter
andreas's Avatar
Ken
Ken - Good luck and have fun. If I can be of assistance just drop me a PM. I may be slow to answer.
Look forward to see your project.
andreas is offline
post #9 of 19 Old 02-02-2010, 12:55 PM
nvr2old's Avatar
Did something similar to my Givi's. Just a single strip for extra taillights. They are fastened with a very high quality double back tape(acquired from Boeing surplus. Really like the idea of the second strip in amber for turn signals. Will post some photos soon.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #10 of 19 Old 02-02-2010, 01:02 PM
nvr2old's Avatar
Photos.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
nvr2old is offline
