Low and High Beam Simultaneously - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 16 Old 01-28-2010, 07:05 AM Thread Starter
I noticed that when I select the high beam only the high beam portion of the bulb illuminates. However, when flash to pass both the high and low beam illuminate. What would I need to do to have the low beam stay on all the time, even when high beam is selected? Flash to pass provides a lot more light than low or high alone, so why not have both on at the same time?
Another reason would be some of the HID kits have HID as the low and Halogen as the high. Switching back and forth turns the HID on and off, not good for any HID.
LiteHeaded is offline
post #2 of 16 Old 01-28-2010, 07:59 AM
kenneth_moore's Avatar
H4 Relay Kit
Eastern Beaver's H4 Relay Kit could be modified pretty easily to run both simultaneously. However, the current draw might be more than either the alternator or the wiring can support on a continuous basis. Doing it without a relay that bypasses the handlebar switches would be a very bad idea; they handlebar switches and wiring can barely support the current draw now.
There is so much light available with SilverStar H4 bulbs and the Eastern Beaver kit, running both beams seems like overkill to me.
Go hakafugu yourself.
kenneth_moore is offline
post #3 of 16 Old 01-28-2010, 10:41 AM
Both beams could also put out more heat than the mounting area could handle. Running lights can be mounted to provide a triangle of light that make it easier for others to notice your bike as well as determine your distance and speed. With HIDs, stick to the type that move the lamp or its shutter to change between lo and hi beams.
post #4 of 16 Old 01-28-2010, 12:31 PM
Steve Koski's Avatar
Y'all probably know this, but the manual says to not run them both with the switch in the middle position.
I used to mid-switch-it all the time on an old Virago. (Not saying that makes it ok.)
Steve Koski is offline
post #5 of 16 Old 01-28-2010, 12:32 PM
OK, so what is the "flash to pass" thing for? Do you flash it before you pass someone?
(Sorry for another stupid newbie question.)
post #6 of 16 Old 01-28-2010, 02:26 PM
I think Eastern Beaver makes a harness that will allow both filaments on at the same time, they also advise against it. Heat can be a problem, also with both lights on, the eye will naturally follow the brightest area, which would be the low beams. When you probably should be focused further ahead. FWIW
Denase is offline
post #7 of 16 Old 01-28-2010, 02:57 PM
V-Tom's Avatar
I don't understand why you really want the lows on at the same time as the highs anyway. My cars do that and it's a bit silly (although one does it because it has Bi-Xenon headlights so turning off the low is not a good idea.)
Why would you want to look at something a few feet in font of you when you should be looking down the road anyway? It's as dumb as people driving along with fog lights on in normal conditions.
As far as flash to pass: I use it all the time to give people a quick notice that I'm passing them. If I am passing a few cars at one time It is even more important to flash it (it would be about the only time I would see any value in a headlight modulator.)
..Tom
JonathanAU likes this.
SMIDSY detailed report.
V-Tom is offline
post #8 of 16 Old 03-04-2010, 08:29 AM
Jeff Kushner's Avatar
Being a guy that loves riding at night, I also found that option of running both high and low. I installed halogen running lights on my forks at the fender bolts but removed the 50 or 55 watt bulbs replacing them with 35's.
I usually run all three when on the roads late at night when there is no other traffic. It does a fantastic job of "lighting my life" near and far and since my right side running light points a little to the right, it illuminates the shoulder as well. I don't worry about the heat since I'm moving on the highway and am religious about switching to low when traffic approaches. To date, I never had any issues with it running my battery down either but I have been curious as to what was happening when I had all three illuminated at the same time.
I was puttering in the garage last night and just for kicks, hooked up the volt meter while cycling the lights. At idle with low beam only I was getting roughly 14-14.5. It was steady as a rock no matter if I reved it to 4500rpm or let it idle. When I added the running lights there was no change. On high beam only there was no change. I have the running lights wired so they do not stay on with the high beam(I can activate the running lights with either low beam or high and low together, but not high alone). BUT when I moved the switch to the middle position and had both low and highs on my voltage dropped to 12 or just over it. It didn't make any difference when I added the running lights . The only time my volts dropped was with high and low on together. I would have expected that adding the running lights to the low/high would have dropped it but it didn't. Aw well....just sharing what I found for whatever it's worth.
jeff
Present only:
My VStrom 1000 K7
Stock bikes: a
purple '74 RD350 in great shape,
'72 H1,
1975 GT550,
All-original 1975 H2 750 triple (purple of course),
Modified bikes:
1974 H2 750(my go-fast), a scary fast & fully ported street machine!
'82 Yam 650 Turbo- running 18PSI, Be sure to be pointed where you want to go!
'75 GT550 built up & ported,
'75- H1 wrist-rocket- HOLY GOD ALMIGHTY!
'75 S1 Kaw 250 baby triple w/ lifted and ported 350cc cylinders/28mm flatslides
To-Restore list: '72 H1, 1-'75 H1, 1974 GT750
Jeff Kushner is offline
post #9 of 16 Old 03-04-2010, 08:51 AM
andreas's Avatar
Flash to Pass is what Europeans do. If a vehicle is in the left lane ( which is against the law in europe unless passing only) you are to give them ample warning that you are coming up fast and want to pass. That person had better move to the right fast, especially in Germany since there is no speed limit.
FB MEMBER #133 - 2008 Wee
andreas is offline
post #10 of 16 Old 03-12-2010, 02:57 PM
But apparently if you have an accident on the Autobahn and you were going over 130 km/h you may very well pay for the damages
http://drive55.org/content/view/22/4/
Accidents occurring at speeds of over 130 kph on the autobahns can result in insurance payment claims being annulled regardless of who was at fault.
shrike is offline
