Eastern Beaver + Kisan = CONFUSION (help?!) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 01-24-2010, 08:37 PM Thread Starter
Craigster's Avatar
Send a message via Skype™ to Craigster
Ok, after an entire day trying to get a Kisan VectraLight LP16 brake flasher / turn signal / running light combo as shown below:
Instructions found at: >click<
I've hit my personal wall.
In brief, the VectraLight has 5 wires in its pigtail:
Blue - power input : 12v when key on
Yellow - left turn signal input : 12v flash signal (high side of bulb)
Green - brake input : 12v from brakes (on when brakes on)
Red - right turn signal input : 12v flash signal (high side of bulb)
Black - ground : chassis ground connection
I hooked in an Eastern Beaver "brake / tail / turn-signal adapter" >click< at the rear connector as shown >here<.
The EB adapter has 6 connecting wires:
Red- auxiliary brake lights
White - auxiliary tail or running lights
Yellow - auxiliary turn signals (left)
Blue - auxiliary turn signals (right)
Black - ground (and can be used with any of the above that also need a ground)
Purple - ?? There is NOTHING about this wire (using a circuit tester, I figure this carries no load at all. 0v regardless of what else is on.
There's a notation in the EB instructions: "connect an alarm signal wire to the blue and yellow wires" - not sure if it's relevant or not.
When I get everything all wired up an connected as follows:
Function: EB Harness LP16
Brake Red Green
Left Signal Yellow Yellow
Ground Black Black
Right Signal Blue Red
Power White Blue
??????? Purple (>???<) -------
Everything works, EXCEPT the stock brake lights don't work any more.
Anyone with any ideas ??? I've had enough of this for one day.
Thanks,
Craig. (K7A DL650)
Craig Thomson
Victoria, BC, Canada
Current Ride:[b][COLOR="Orange"] 2011 Wee-Strom 650[/COLOR][/B]
Craigster is offline
post #2 of 5 Old 01-24-2010, 09:19 PM
The red and purple wires are input and output to the brake lights to wire a BackoffXP brake light Modulator between them to modulate the stock brake light. The VectraLight doesn't modulate the stock brake light. Basically, you should have gotten version 1 instead of version 2 of the EB adapter. It appears connecting the purple wire to the red wire of the EB adapter will fix the problem.
post #3 of 5 Old 01-24-2010, 09:29 PM
Didn't know those adapters were that "involved"...good to know!
Ed S is offline
post #4 of 5 Old 01-24-2010, 10:04 PM Thread Starter
Craigster's Avatar
Thank you, GreyWolf. Problem solved~!~
C
Craig Thomson
post #5 of 5 Old 01-24-2010, 10:07 PM Thread Starter
Craigster's Avatar
The adapters from EB are first rate. MY confusion resulted from ordering the wrong part from EB. Mental note to self, when in doubt email the mftr...or...post on the board. Could have saved a world of grief -- but it's grief by my own doing.
C
Craig Thomson
