Size 13 boot and shift lever - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 06-02-2006, 08:27 PM Thread Starter
Anyone know of an aftermarket shift lever that would allow me to wear proper foot wear? Can't get my size 13 Red Wings under the lever and raising the lever would be inconvenient as I already have to occasionally lift my foot off the peg in order to catch the ratchet fo the next down shift.
Thanks, Mike
05 DL 1000 (SUV)
70 Triumph Bonnie (MGB)
60 Matchless G-12 (MGTD)
mike is offline
post #2 of 10 Old 06-02-2006, 09:29 PM
The shift lever for the Strom is pretty unique. I don't know of anyone making a longer one. It sounds like you may have to modify your existing lever. If you are not into fabing and welding, then take it to a shop that does. For them it's an easy mod and maybe cheaper than a replacement.
2006 DL650
1982 Yamaha 550 Vision
1977 XS360 Yamaha
I'm on a perpetual search for unused roads.
Fearless Freep is offline
post #3 of 10 Old 06-02-2006, 09:36 PM
kurt1305
I have no idea if this would solve your problem or not, but it does mount directly to the shift shaft.
http://www.touratech-usa.com/shop/sh...34AD377730A95D
post #4 of 10 Old 06-02-2006, 10:51 PM
Size 13's
Well, I have those banana boat size 13's, too. Tho mine are not in Redwings. I adjusted my shift lever and its not too bad now. I get my boot under the lever for upshifts, but I do have to pick up my foot usually on the downshifts. I suggest you try adjusting a bit more before you go to the expense of replacement or refabbing. Good luck with it!
2005 DL1000 Black
Suzuki Hard Side Bags
Suzuki Center Stand
Suzuki Heated Grips
EBC Brake Pads
Powerlet Accessory Outlet
Suzuki Tank Cover
Fenda Extenda (Front Only)
Back Off (Strobe Brake Light)
CaseyStromRider is offline
post #5 of 10 Old 06-03-2006, 01:10 AM
Warren's Avatar
I only have size 12's, but I've found a lot of standard boots are too thick in the toe as cause clearance issues.
A motorcycle-specific boot tapers down more and is much easier to ride with, and if you look around there are some others out there as well with a thinner profile.
Check out Boot World if you have one near, and look at some of the different profiles.
[B]-- Warren in San Diego --
-- 2013 KLR 650 --[/B]
-- [URL="http://www.klr650.net/forums/showthread.php?t=47348"][COLOR=blue]Click Here For My Free KLR Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
-- [URL="http://www.vstrom.info/Smf/index.php/topic,10863.0.html"][COLOR=blue]Click Here For My Free V-Strom Valve Adjustment Shim Calculator[/COLOR][/URL][COLOR=blue] [/COLOR] --
Warren is offline
post #6 of 10 Old 06-03-2006, 10:35 AM Thread Starter
Re: shift lever
Thanks for the info. The tourtech lever looks interesting - the direct fit on the shaft would seem extend it quite a bit. I'll play around with the various suggestions and let you folks know what happens.
Peace, Mike
05 DL 1000 (SUV)
mike is offline
post #7 of 10 Old 06-03-2006, 11:46 AM
BGS
I have size 15 EEE boots - and I have ordered the tourtech shifter to see if it will make a difference. Right now I am using the overlaping edge of the sole plate on the ball of my foot to lift the shifter. (if you can imagine the shifter rides on the inside edge of the ball of my foot about 2" behind the knuckle on my big toe) It gets a little uncomfortable but not too bad. I'll report back when I get the tourtech shifter.
Steve
DL1000K3
BGS is offline
post #8 of 10 Old 06-03-2006, 02:44 PM
BGS
I do not think the tourtech will help you much. It would be designed for the majority of riders. You obviously are not in that category. Spend the money as suggested by Fearless and mod the stocker to YOUR dimensions. A custom fit might be the best thing for you.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #9 of 10 Old 06-06-2006, 05:46 PM Thread Starter
Problem Solved
Got the shifter extended 1 inch. It seems like an easy job as it was ready the next day and only cost $20 CDN. Got pics, but do not know any "publically accessed web server". Anyhow, extra length added near toe. Barely visible.
Works perfectly for me.
Later, Mike
05 DL 1000 (SUV)
mike is offline
post #10 of 10 Old 06-06-2006, 09:20 PM
Mike
Good for you and your flippers. No doubt your comfort level just went up.
05 / 650 in blue
75/Suzuki 125 RV
