oil leakage from water pump - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 05-29-2006, 05:02 PM Thread Starter
mokusbajusz's Avatar
Hello Stromfellows,
I noticed some leakage at the right side of the engine.
I think it is from the water pump and may be oil, but not sure.
Did any of you have seen the same?
Shall I worry about it?
I don't want to wash the bike so the dealer can have a look on it.
It is something I didn't get used to meet with on my previous Hondas. :evil:
(don't mind about the oil level shown, the bike was on side stand)
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
mokusbajusz is offline
post #2 of 5 Old 05-29-2006, 06:23 PM
Check this bolt first before condeming the water pump, make sure it's snug. There have been several instances with this not tight enough to seal. What ever you do, don't remove it. It relates to the cam chain tensioner and if not done properly, you can end up with a real problem.
nighthawk is offline
post #3 of 5 Old 05-29-2006, 07:11 PM
kurt1305
Looks like radiator fluid with road grime. I had a drip on my 1000 until I tightened all the hose clamps. Problem solved.
post #4 of 5 Old 05-29-2006, 09:29 PM
A good idea is to check all the cooling system fittings and snug them up a touch. This is part of the Pre-delivery inspection process in the auto industry. Should be for bikes too, maybe it is. Checked my fittings at 3000 kms and snugged them.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #5 of 5 Old 05-30-2006, 12:16 PM Thread Starter
Thank you friends for advices, I will check the things you mentioned at the weekend and wash the bike. So I can check if the problem solved with tightening the screws.
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
