HID conversion - which did you use? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 36 Old 11-18-2009, 06:44 AM Thread Starter
rebeccav's Avatar
I am considering converting my 05 Wee to an HID low-beam to save some watts.
If anyone has done this, please tell me about the product you used, how the install was and if you like the product/results.
I'm also considering LED taillights and conspicuity lights (ditching my beloved Motolights). Any input is helpful.
rebeccav is offline
post #2 of 36 Old 11-18-2009, 06:57 AM
Roy Bertalotto used this one and was very pleased with it. http://www.rvbprecision.com/motorcyc...otorcycle.html
http://www.vvme.com/standard-h439003...cPath=44_46_35
Before I knew about it, I went with http://www.futurevisionhid.com/catal.../33/category/9
I'm happy with it's function but it's quite a bit more for what appears to be the identical item.
post #3 of 36 Old 11-18-2009, 07:08 AM
tmcgee's Avatar
I used this HID kit about a month ago. About $90 shipped via DHL from Beijing. http://tinyurl.com/y9chaz9 (same set that Roy used.)
I took the cowls off and spent the better part of a morning installing it (although I did a few other things at the same time). It took a few hours to wire it up, dress the mess, and secure everything. I'm very happy with the results and wouldn't go back to halogen.
It's important to get the digital slim ballasts because of the small size, because they draw less power than the large ballasts and because the lamps start up right away.
It's not strictly plug and play. I modified the provided harness slightly to fit the bike since what they give you is really designed for a car. Essentially, all I had to change was to lengthen the wires to reach the battery. You do NOT have to cut any of the bike's wiring.
tmcgee is offline
post #4 of 36 Old 11-18-2009, 07:21 AM Thread Starter
rebeccav's Avatar
The info is greatly appreciated - thanks greywolf and tmcgee.
rebeccav is offline
post #5 of 36 Old 11-18-2009, 07:22 AM
HID headlights are especially good for those who ride with heated gear. The 35W HIDs draw less power than 55W halogens, are brighter and do not dim when the heated gear is on. My headlights used to look like they had modulators on as the Heat-Troller cycled the heated gear a portion of every second. The HID lights are steady when fed anything from about 9-16V. I really like the 4300 degree color temperature type. It provides the most light and is only slightly bluer than stock lights.
post #6 of 36 Old 11-18-2009, 08:31 AM
tmcgee's Avatar
According to Phillips, all HID lights labeled as 35 watts are actually 39 watts and full-sized ballasts draw another 8 watts each. I could not find a power spec for digital ballasts, but would expect them to draw about half the power. A ballast is essentially a power transformer and the digital ones are akin to switch-mode power supplies -- much more efficient.
tmcgee is offline
post #7 of 36 Old 11-18-2009, 09:05 AM
35W HIDs with slim ballasts appear to draw an actual 40-44W from what I've read. All I can say is my voltmeter has never provided such steady numbers or allowed so much heat to be provided before.
post #8 of 36 Old 11-18-2009, 09:10 AM
tmcgee's Avatar
Those power figures make sense to me, Pat. And my results with voltage readings and heated gear match yours. :mrgreen:
tmcgee is offline
post #9 of 36 Old 11-18-2009, 09:47 AM
I am looking to save some power to run a pair of Solstice VisionX lights, heated grips, and a Tourmaster heated vest. I am considering either HID conversion or EB low beam kill switch. After reading thisw thread it seams that the actual 10-12 watt savings per light that you get from the HID conversion don't measure up to the 55w savings that you get from killing one of your low beams. If I put manual switches on everything then I would have the most control over my piwer consumption.
Any thoughtso
[B]2005 Red DL650[/B]: EB fuse panel, OEM center stand, gel Seat, Madstad adjustable windscreen, SW-Motech crash guards, SW-Motech quick release side and top racks, black Trax ALU-BOX side and top cases, electrified Cortech Super 10 tank bag, dual tool tubes.
Projects planned or sitting in my garage waiting for time: Oxford Heaterz (waiting for time), handguards, aux lights, and new paint (waiting for money).
[B]Triumph Street [I]III[/I][/B]: plain vanilla, go fast bike.
[B]ATGATT[/B]
[URL="http://www.maya-research.org"]Maya Research Program[/URL]
chacbalam is offline
post #10 of 36 Old 11-18-2009, 10:06 AM
I still have a headlight cut out switch. The HIDs allow much better night riding, especially with the brightness not cycling when a Heat-Troller is used. The HID kit isn't a whole lot more expensive than a dual headlight relay kit and includes a headlight relay.
