custom made lowering link - material question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 05-25-2006, 04:51 PM Thread Starter
mokusbajusz's Avatar
Hello to all Stromtroopers
My custom made lowering links just arrived.
They are cut with water jet cutter, the wholes are CNC machined.
The material is stainless steel (EN: 1 4301 or ASTM: 304, JIS: SUS 304).
I know stainless steels are not so strong than compound steels.
My question: what do you think, has that part the approriate strength for use as a link?
Or
What are the maximal loads on the links while in use?
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
mokusbajusz is offline
post #2 of 13 Old 05-25-2006, 07:35 PM
stainless steel is not only harder but also has a higher tensile strength than regular carbon/cold rolled steels. Almost all of the loads will be in tension for this part.
304 is the most common Stainless steel.
I made mine out of SS too. From the looks I even went with a shade thinner material.
They will be just fine.
sideways and smiling
WIsixfitty is offline
post #3 of 13 Old 05-25-2006, 09:16 PM
As someone who deals with all kinds of stainless steel, every day, I couldn't agree more with WIsixfitty, except... A very high carbon steel will be "harder" but typical Stainless is much tougher..
That link, made of 304 SS will outlast the bike, several times over..
If it were mine, I'd polish it up to give it a good shine and slap it in, and forget about it forever.. It's got a mill finish, so I'd hit it with a 80 grit sanding disk, and then the highest grit thing you can find, or Scotchbrite to put a shine on it.. Just remember never to grind or polish with something that's been used on mild steel.. Always use a new disk, or you'll impregnate mild steel into it and cause it to rust..
There, now you know more about your link than you'll ever need.. :lol:
humbug
Paper is offline
post #4 of 13 Old 05-25-2006, 09:58 PM
I remember drilling my own brake discs back before they came that way. I sometimes think I spent as much time sharpening drill bits as I did drilling holes. SS is tough stuff.
post #5 of 13 Old 05-25-2006, 10:05 PM
The problem with SS is that unless you have a sharp drill, and go at it like it life or death that you have the hole, the SS work hardens ahead of the bit.. Lots of lube and a sharp bit are the key..
I'm usually working with 316 and 317, and occasionally Hasteloy.. They make 304 seem like a dream to drill.. :shock:
I'll be those discs were REALLY work hardened before you even started on them.. That's tough drilling!! :lol:
humbug
Paper is offline
post #6 of 13 Old 05-26-2006, 12:55 PM Thread Starter
Thank you guys for your kind help!
I also planned to make it shiny, moreover even to engrave something like "Stromtrooper" or "Karalink" (my family name is Karakas) or the V-Strom logo or...
Would it be too extreme or cheesy?
I will install them tomorrow, took some shots and will post a report.
There come something to my mind which makes unnecessary to have a helper/supporter while installation. Will see if works.
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
post #7 of 13 Old 05-27-2006, 01:29 AM
Karalink sounds good to me. You are proud of your family name so why not ? It would look cool and you might start making Karalinks for other Strom riders too. Like they say " It Pays To Advertise ". Could be a money making hobby. You could buy more Farkles .
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #8 of 13 Old 05-28-2006, 05:02 PM Thread Starter
Hello Stromfellows,
I finished with the installation of my custom made lowering links.
Normally the whole process shouldn't take more than about 20 minutes.
Mine took 3 hours due to documentation... ...and some grinding... ...smoking... ...and polishing... ...drinking... ...wrenching... ...enjoying... 8)
After the installation the seat height is lower by 15-20 mm. Unfortunately I still cannot flat foot.:evil: although the front forks are already raised by 15 mm. So the next (longer) link is under calculation.
Impressions after 50 Km twisty test ride:
The bike behaves noticeably more stable in curves but on the other hand turns less easy. It is simply amazing how big is the impact of such a small mod! After the front fork raise I felt the same huge (positive) change in the curving.
Ohh not to forget: pegs are still not in danger...:wink:
The complete story can be seen here with bilingual explanation, just click on a thumbnail:
http://www.freeweb.hu/dl650/fotoalbu...ion/index.html
Here is a few pics to key you up:
Measuring initial seat height:
Grinding and polishing:
Shiny isn't it?
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
post #9 of 13 Old 05-28-2006, 06:54 PM
Very nice looking links. We have a craftsman in our midst. After you have made another set for further lowering you will have two sets of dimensions and their results. This should help others of short stature who are considering lowering their bike. Mod On.
05 / 650 in blue
75/Suzuki 125 RV
post #10 of 13 Old 05-28-2006, 09:16 PM
15 - 20 mm is about .6 to .8 inches but it looks like it lowered it more than an inch in the photos if you look on the link.
2006 Suzuki Vstrom DL1000 (Red)
RoyalStromdad is offline
