Fork springs versus fork brace - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 10-30-2009, 02:57 PM Thread Starter
I ride a '05 DL1000 and I weigh 255 lbs. I installed a fork brace (which improved handling) and my question is this. Does the fork brace replace the need for heavier fork springs or should I also install the heavier fork springs.
austin03 is offline
post #2 of 11 Old 10-30-2009, 03:16 PM
SCraig's Avatar
Fork braces and springs are completely different. The only thing that they share is that they can both improve handling characteristics.
A fork brace helps prevent the fork tubes from flexing and twisting. It has nothing to do with the spring rate. The springs provide suspension.
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 11 Old 10-30-2009, 03:22 PM
GT_Hawk's Avatar
one thing someone said in here that makes sence is try using a higher forl oil. stock is 5T, try going to 10T or 15T even. May be enough for you, or you may feel you want more. Personlly I think the bike nose dives to much for me so fork oil may help else new springs. But hey 80$ gets new springs. I got fork brace as well btw
GT_Hawk is offline
post #4 of 11 Old 10-30-2009, 04:06 PM
Rjsurfer
Well, heavier fork oil won't decrease the "amount" of brake dive your experiencing just how fast they dive...only heavier springs will shorten how far they dive.
Heavier springs are a good invesment, check out Sonic Springs good quality springs and good product support.
Ron W.
07 Wee
07 DRZ400 SM (wifeys)
16 T Sprocket
Short screen & Washers
Replaced 'P" shooter
35W halogen rear signals
RT Gold Valves
Sonic Springs
rjsurfer is offline
post #5 of 11 Old 10-30-2009, 05:07 PM
CHIA's Avatar
At 255lbs, you will feel a day & night difference by upgrading to heavier springs.
It's one of the least expensive and tangible handling changes you can make on some bikes.
I'm 225lbs, and will absolutely be upgrading my springs next season.
CHIA is offline
post #6 of 11 Old 10-30-2009, 05:18 PM
GT_Hawk's Avatar
now her eis a question, will the ride itself suffer, IE will changing to sonic springs make the bile a lot less comfortable to not noticeable idea. In cars harder springs mean harder ride but cornering becomes much more fun, so trying to get down the diea of motorcycling handling still.
GT_Hawk is offline
post #7 of 11 Old 10-30-2009, 08:22 PM
Fork spring keep the front end in proper position. Oil height and weight controls dampening. Raise the height or high weight changes dampening by slowing down the rate the fork moves (up and down). Heavier springs with lighter weight (5w) is the best package and the ride quality is better.
2003 V - ASV C5 Levers, Univ. Solex bars, grip heaters, ktm mirrors, c.stand, SW Mo Engine grds,Two Bros, PC3, Garmin, Givi 460, tank bag, F. Extenda, BackOff, Super Brace, Elka Shock, Race Tech Gold. AWD/Mr.Ed's Moto seat mod. Dumonde Tech Racing Oil, Spider grips, Contour.
2001 KTM LC4 farkled (sold)
awd505 is offline
post #8 of 11 Old 11-03-2009, 08:37 PM
RTL
RTL's Avatar
I weigh 225 lbs. and have done the following to my DL1000 K3 suspension:
Sonic 1.0 fork springs-$80
Silkolene 5 wt. fork oil to factory fill specs.-$25
Richland Rick fork brace-$80
Cleaned and greased all rear suspension pivot points-$5
Sasquatch Suspension rear shock rebuild with stiffer spring-$450+shipping
I did all of the work myself so saved significant money there. In short the bike is transformed! The handling is awesome and my sport bike buddies can't believe how nice it rides and how well it corners.
RTL is offline
post #9 of 11 Old 11-03-2009, 10:14 PM
Travman's Avatar
When I bought my DL1000 this summer the PO gave me a set of Sonic Springs that he never got a chance to install. From what I am reading, I should have them put in. Question, this is well beyond my mechanical abilities, about how much would a dealer charge to do this and would they know how to do it correctly.
Thanks,
T
All who wander are not lost!
2008 DL1000 - Silver - gone
2008 Suzuki Burgman 650 Exec - gone
2007 Suzuki Burgman 400 - gone
Travman is offline
post #10 of 11 Old 11-04-2009, 10:21 PM
RTL
RTL's Avatar
I can't answer that one. I do my own work because I can. I would be very careful and try to find out from others who does quality work regardless of price.
RTL is offline
