High Output Alternator? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 26 Old 10-09-2009, 11:14 AM Thread Starter
Good day;
I have an '05 1000 and am looking into getting a higher output alternator to handle the heating requirements for two up riding. The vests, grips, etc., that I use draw too much juice (the PIAA lights are the biggest offender) and would like a high quality unit.
Any suggestions?
Thanks in advance,
Jack
jackroten is offline
post #2 of 26 Old 10-09-2009, 11:39 AM
tmcgee's Avatar
Originally Posted by jackroten View Post
Good day;
Any suggestions?
Thanks in advance,
Jack
Getting a different bike is prolly your only option.
tmcgee is offline
post #3 of 26 Old 10-09-2009, 11:50 AM
The answer is that you pretty much have no options. Electrosport has a high failure rate for their higher output alternators. You can use less heated gear, ride when it aint so damn cold, or you may have to get a different bike.
post #4 of 26 Old 10-09-2009, 12:20 PM
16171
Our bikes don't even have an alternator...I'm just sayin...
BTD.
post #5 of 26 Old 10-09-2009, 01:23 PM
dtalk's Avatar
Were I you, I would replace those with good quality LED lightheads (such as Whelen's public safety lights). That'll save you a bunch of electrons.
You can't do much about the supply side, but you can do better on the demand side.
dtalk is offline
post #6 of 26 Old 10-09-2009, 09:57 PM
rcacs's Avatar
Although i do have 55w aux lights, I dont use them if I am running all my heated gear and grips, or 2 vests, heated gloves, etc.
I also have a EB low beam cut off (one headlight) to ensure I have adequite supply.
To answer your question though, there currently is no high output alternator available, other than the forementioned high failure unit.
Cheers
rcacs is offline
post #7 of 26 Old 10-10-2009, 11:24 AM Thread Starter
Thanks!
Thanks to all that responded. I won't use the PIAA's and should be fine.
Jack
post #8 of 26 Old 10-10-2009, 11:48 AM
GT_Hawk's Avatar
https://www.stromtrooper.com/showthre...light=Solstice
Take a look down at the first 2 bike pictured. Thsoe are 1 led lights with
around 30-50 watt output of normal ligths. Found them for 12$ each.
http://www.dealextreme.com/details.dx/sku.11263
Not the nicest but if tucked under the fearings all you see is the extra
ligths. Only take 10watts power each so solves the power issue.
Here is a much nicer lookign style people ahve also used on bikes
http://www.visionxoffroad.com/led/s1100/
here is a thread on the pricey lights being installed
http://www.advrider.com/forums/showthread.php?t=481009
I did find another set of the cheaper ones with diffrent specs ie a 3 watt and 1 watt version and diffrent spreads. Have to hunt that down
GT_Hawk is offline
post #9 of 26 Old 10-10-2009, 08:35 PM
randyo's Avatar
I've been searching thru parts fiche looking at bikes with high outputs
BMW utilizes a belt driven 60amp (800watt) generator about $800
Goldwing has a 1300watt alternator $400
now if someone could come up with a kit to adapt to the V-strom, I kinda like the idea of a 100 amp alternator, that's bigger than most cars
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #10 of 26 Old 10-10-2009, 10:13 PM
Some aircraft use wind driven generators.
Just an idea.
Mountaintime is offline
