Fork gaiters - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 09-12-2009, 08:59 AM Thread Starter
Heavy's Avatar
Fork gaiters
I'm not using these myself but they look like they'd be pretty good for protecting those exposed fork tubes.
http://www.kriega.com/pages_uk/forks...-frameset.html
I used the DirtSkins covers up until I installed a fork brace and they kept my forks very clean. Only problem was they would slip off the fork slider from time to time. The others, above, have little loops on them that you can run a zip-tie through to hold them better.
http://www.dirtskins.com/Item.asp?IID=73
DL1000K6
Heavy is offline
post #2 of 6 Old 09-12-2009, 11:12 AM
I don't know how they could be used with a fork brace though.
post #3 of 6 Old 09-12-2009, 11:42 AM
What Kinda Bike Is That?
Black Lab's Avatar
I use this product for forktube protection: Shockmate #SA1997, (I believe Greywolf uses the cross-referenced Rancho product.)
The tops of the boots are "wire-tied" to the forktubes just under the triple tree. The inherent "spring-like" construction, along with gravity, lets them hang down to my forkbrace.
Yet, I can easily slide them up to check the fork seals, (also something that needs to be done during bike inspections in the state of Maine.).
Black Lab is offline
post #4 of 6 Old 09-12-2009, 11:58 AM
The springiness of the accordian types keep them against the brace. Mine don't have any mechanical attachment at the bottom and work fine. The neoprene skins only connect top of the fork leg and don't have any spring to them.
post #5 of 6 Old 09-13-2009, 08:52 AM Thread Starter
Heavy's Avatar
Originally Posted by Heavy View Post
...I used the DirtSkins covers up until I installed a fork brace...
You are correct, they don't work with a fork brace. But I'd be willing to bet there are a few Stroms out there that still aren't running a brace.
DL1000K6
Heavy is offline
post #6 of 6 Old 09-13-2009, 11:46 AM
Looks like a good option Heavy, I actually have "similar type" stock guards on my C14.
