Grip Puppies vs. Home-made puppies - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 09-06-2009, 11:38 PM Thread Starter
Valentine's Avatar
I bought a pair of Grip Puppies for my V-Strom - - nice. But, I also own a 1974 Kawasaki 900Z (116,000 miles). The grips on this bike are considerably larger than the V-Strom - - so big, in fact, that Grip Puppies do even come close to fitting. What’s a guy to do ??
The guy must use that little known activity known as “THINKING”. So what is made of foam, cylindrical in shape with a hole in the middle ?? Answer - - foam pipe insulation.
I went to Lowe’s and purchased a 6 foot length of pipe insulation for $3. This specific foam is black and has a self-sealing seam. This means that after cutting it to the proper length for the hand grip and slipping it on, you can press it together and, so far, it has stayed sealed.. But, if it eventually becomes unsealed, I will use black electrical tape or, perhaps, black plastic ties. The foam insulation also comes in varying internal diameters so you will be able to find something that fits your grips. Some foam insulation comes without the slit so, in theory, if you find the proper internal diameter, you could slip this over your grips just like the Grip Puppies.
Valentine is offline
post #2 of 7 Old 09-07-2009, 12:44 AM
Foam pushbike grips work over the Suzuki grips. A lot cheaper than grip puppies and very durable.
Pete
PeteW is offline
post #3 of 7 Old 09-07-2009, 03:23 AM
CHIA's Avatar
Pete
Pushbike grips? Link, details?
CHIA is offline
post #4 of 7 Old 09-07-2009, 04:38 AM
They look like this:
http://www.grabongrips.com/bicycle.php
Or this:
http://www.grip-tek.com/
Take a look at the continuous foam tubing - which is closest to what I used.
Most bike and even sports stores here have the generic version in packs.
I picked up a pack of 4 for $8.
Since I cut them in half and put half on each side it's pretty good value.
Pete
PeteW is offline
post #5 of 7 Old 09-07-2009, 06:10 AM
garandman's Avatar
On my old bike I used a tennis grip. A few bucks, you have a wide choice fo textures, they are self-adhesive and spiral on, and one does both handgrips.
I'd like to do something as the grip puppies don't fit over the Hot Grips.
garandman is offline
post #6 of 7 Old 09-07-2009, 07:29 AM
Rjsurfer
I use plain old bicycle tape. You can make the grip any size you want, comes in great colors and since it doesn't have the word "motorcycle" attached to it, it's cheap.
Ron W.
07 Wee
07 DRZ400 SM (wifeys)
16 T Sprocket
Short screen & Washers
Replaced 'P" shooter
35W halogen rear signals
RT Gold Valves
Sonic Springs
rjsurfer is offline
post #7 of 7 Old 09-21-2009, 09:50 PM
banjobart's Avatar
Grip puppies are only $9 a pair with free shipping. There is a large size for Gold Wings that may fit that Kawasaki 900Z. Available from:
www.casporttouring.com
2007 DL1000
2013 CB1100
2013 Ninja 1000
2011 GSX1250
2007 FJR1300
banjobart is offline
