Air horn - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 09-02-2009, 09:49 AM Thread Starter
Air horn
I saw a air horn on riderswearhouse.com called the Ear Cannon Air Horn. They charge $37 for the horn and $12 for the wiring adapter. Anybody here installed one of these on their strom? I live in Austin Texas and the drivers here run over you first and then look.
austin03 is offline
post #2 of 7 Old 09-02-2009, 11:17 AM
Dr. M's Avatar
Do a search on "strebel." You'll find LOTS of people are using air horns and there are several threads showing exactly how to install the horns. The $39 strebel rip-off that Harbor Freight sells works just fine. You really don't need a $12 wiring harness if you have some extra wire and spade crimp connectors laying around.
2008 DL1000, Two Brothers, PCV, etc., etc.
2008 GSX1340R Hayabusa, Velocity Racing Turbo, boost controller, water injected
2002 CBR600F4i
2008 GSX-R600, Akrapovic full Ti, PCV w/AutoTune
DynoJet 250 dynamometer (just learning to use it)
Dr. M is offline
post #3 of 7 Old 09-02-2009, 12:16 PM
Canvas6st's Avatar
Air horn-
Search "stebel" and you'll get even more results.
I've got the one from Harbor Freight (the Wolo Bad Boy) mounted under my right faring and it's pretty impressive sounding. I've seen a lot of the Harley guys with them mounted under chrome covers. They're pretty popular. There's a wiring harness from easternbeaver.com made specifically for the v-strom, and while it's a little more than 12 bucks, it's worth it to have something custom fit. It also comes with a better relay to replace the super cheap one that comes with the horn.
[SIZE="1"]Orange K9 Wee - Givi guards and screen, Zuk hand-guards, Madstad, Rick's fork brace, Shad topcase, Sargent seat, Rox risers, Vessel luggage bracket and sheepskin, Tuono Mirrors, CL-850 bags, Wolo horn, Powerlet.
[/SIZE]
Canvas6st is offline
post #4 of 7 Old 09-02-2009, 01:30 PM Thread Starter
Was it hard to mount the air horn in place of the stock horn or did you have to modify the mounting. Was the harness from easternbeaver difficult to install or did you have to remove body panels? Last but not least, does the WOLO bad boy air horn catch idiot drivers attention?
austin03 is offline
post #5 of 7 Old 09-02-2009, 03:57 PM
Dr. M's Avatar
Oooppps! My bad!
The Harbor Freight horn will stop an antelope at 100 yards and will get the attention of any texting teenager driving mom's grocery getter. They're even louder than a 4-door import wing equipped low rider with a fart can... seriously... they're loud.
2002 CBR600F4i
Dr. M is offline
post #6 of 7 Old 11-30-2009, 10:25 PM
fredellarby's Avatar
The stebel works well but you don't want to try putting it up where the original is. I did it easily with wire, a relay and connectors.
Here's what I followed.
https://www.stromtrooper.com/forums/s...ad.php?t=10631
Fred
I'm not always sarcastic.
Sometimes I'm facetious.
Or ironic.....
If a tree falls in a forest and lands on a politician, even if you can't hear the tree or the screams, I'll bet you'd at least hear the applause.”
Paul Tindale
fredellarby is offline
post #7 of 7 Old 12-03-2009, 11:07 PM
I had not ridden much this year, and didn't use the horn at all. Then when I went to show someone how loud the horn was, it only worked a little bit...only one note!! I hit the button a few more times..for just 2 seconds each, and felt pretty embarrassed. I was not in a place where I should be blasting a horn anyway.
So once out on the road with no one around, I held down the horn button for about 3-4 seconds and all came back to life!! It worked fine the rest of the ride. So exercise that horn every once in a while or it may not be there when you need it!!
The grass may look greener, but there is probably more POOP in it!
Columbo is offline
