Bleeding GSXR brake calipers - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 08-29-2009, 08:45 AM Thread Starter
acormier7's Avatar
I went to mount and bleed my GSXR brakes on my V-Strom yesterday and am having a hell of a time bleeding them. I'm using a vacuum bleeder. I had 4 piston R1 brakes on my RZ350 and it wasn't a problem at all. Any special tricks?
Thanks,
Art in Edmonton
14 DL650
03 DL1000 SOLD
acormier7 is offline
post #2 of 3 Old 08-29-2009, 01:45 PM
16171
I'll give you a good suggestion...prefill the calipers as much as possible through the bleeder screw(use an ear syringe), hook up all the lines and such, fill the master cylinder to the top, then crack the bleeder screws...and let it sit over night. Let gravity do it's thing for a good 8-10 hrs. In the morning, top off the master cylinder and bleed as normal. Don't worry if your master cylinder runs empty over night...as you're bleeding them anyway.
BTD.
post #3 of 3 Old 08-29-2009, 02:53 PM
bill l's Avatar
Double wrap the threads on the bleeders with teflon tape. Works like a charm. Says to do this in the directions with the Mityvac.
64 Hon cub 50, 67 Hon trail 90, 68 Yam 180 twin, 66 Hon 305 dream, 71 Yam 175 enduro, 73 Yam tx500, 70 Hon sl100, 75 Hon xl250, 79 Yam sr500 , 95 Kaw en500, 98 Hon cb750, 02 Yam fz1, 06 Suz dl650, 07 Hon ST1300
Avatar:
https://www.stromtrooper.com/forums/a...4&d=1170279743
bill l is offline
