Night Rider LED install advice needed - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 08-06-2009, 11:35 AM Thread Starter
Send a message via Yahoo to viclava
Has anyone installed one of the Custom Dynamics Night Rider LED's? I have before on my Honda Sabre, but it looks like the brake wiring is harder to get to on the DL1000. I want to install it on the license plate frame and wire into brake wiring without having any wiring exposed.
Any advice would be much appreciated.
Scott
viclava is offline
post #2 of 3 Old 08-06-2009, 11:48 AM
Dread7's Avatar
Yeah I'm running one. But I have mine mounted on the back of the luggage rack below my top case so that might not help you. The brake wiring is probably in the same place on a 1000 as it is on my 650. I used posi-tap connectors to connect to the brake wiring and add three pieces of wire. Then I use posi-lock connectors to add just about anything I want. So far I have the night rider, the top case and my fuse box switching wire running from there. It bundles up neatly and just runs along the rail.
Formerly clovett but changed to my gaming name
2004 DL650 1998 DR650 1994 CB1000 1992 DR350
2004 Z400 1965 Norton 650 1984 Honda XL200
1975 Suzuki RM125 1972 Yamaha 100 enduro
1971 Honda CT90 1968 Honda Z50A
Dread7 is offline
post #3 of 3 Old 08-06-2009, 12:32 PM
SCraig's Avatar
It's a 10 minute job to remove the entire rear fender and expose all the wiring. That's about as easy as it gets.
Scott Craig - Nashville, TN
SCraig is offline
