PC III Uninstall - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By Gert
  • 1 Post By Big B
post #1 of 6 Old 10-12-2019, 04:58 PM Thread Starter
BLW
PC III Uninstall
Hello all,
I have searched the internet and this site and cant find an answer to my question that works for me. My07 DL1000 will stall and run very crappy after rides of over 25 miles or so, usually i just use it for commuting to work (7 miles) so its a non issue on most days.It has a PC III on it and I would like to ride it without it to see if this is the problem,everywhere says that you just have to unplug it and plug the old connectors back together to get rid of it. I did this today and the bike wouldnt start and gave me the red FI light.Any help would be appreciated
BLW is offline
post #2 of 6 Old 10-13-2019, 05:01 AM
Gert's Avatar
Try starting with the throttle cranked open. It could be that the idling is set too low or that you may have disconnected the wrong connector.
vegashotwheeler likes this.
Gert is offline
post #3 of 6 Old 10-13-2019, 10:42 AM
Highly doubt the PCIII, sounds like a TPS sensor going bad....that's how they act.
post #4 of 6 Old 10-19-2019, 09:15 PM Thread Starter
BLW
I followed the wiring harness from the PCIII up to the left hand side of the bike under the gas tank. I disconnected it and hooked the 2 connectors from the stock wiring harness back together.I hooked the battery back up and tried to start it, with the throttle wide open and closed, it never even sputtered and the FI light was on. Thanks for your input.
BLW is offline
post #5 of 6 Old 10-19-2019, 09:18 PM Thread Starter
BLW
Thanks for the input on the TPS , i will look in my manual for testing procedures on it.
BLW is offline
post #6 of 6 Old 10-20-2019, 04:11 AM
Gert's Avatar
If I understand you correctly, the fuel pump is priming with the ignition switched on, so the cutout switch is in the run position and the neutral light is on (out of gear) plus there is no CHECK on the display? The clutch switch is making contact and the starter motor turns the engine when depressing the starter button but the engine does not start?
Have you tried placing your bike into dealer mode, https://www.vstrom.info/Smf/index.php/topic,7061.0.html or https://www.stromtrooper.com/4569938-post5.html If you can get a display of the FI error code, it should help with the diagnostics.
What is the condition of the battery and terminals? If the battery is faulty, in that, there may not be enough amps to crank the motor or to prime the fuel pump. There have been a few reports of the stator magnets that have moved / damaged stator, https://www.stromtrooper.com/dl1000-...-pictures.html.
Also if the CKPS is loose, https://www.stromtrooper.com/dl650a-...-12-error.html, the bike will crank but not start. Was any work was done in this area prior to the problem that you are having?
Gert is offline
