Powering my relay? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 04-25-2006, 05:26 AM Thread Starter
YellowDemon's Avatar
Powering my relay?
I'm looking to add a Blue Sea Fuse box but only want it powered on when the ignition is turned on hence I want to use a relay.
I know I could vampire into the Tail and Rear lights but I've noticed a spare? spade female connector on the left hand side(Rectifier side) but towards the rear of the bike.
I checked the voltage on it this morning with the engine off and 0V. Put the key in and turned it and it reads 12V. Looks promising.
Does anyone know what this connector is for and could I use it to power my relay?
YellowDemon is offline
post #2 of 12 Old 04-25-2006, 01:52 PM
I'm not familar with the connector you speak of, but if it's not being used, what could go wrong? The relay draws almost no power.
- Mark
markjenn is offline
post #3 of 12 Old 04-25-2006, 03:18 PM
MATTMAN's Avatar
Probably the OEM heated grip plug. This is what most people use to energize a relay. A horn lead will plug into it.
650...Anything more than a handfull is wasted
MATTMAN is offline
post #4 of 12 Old 04-25-2006, 03:30 PM
Isn't the heated grip connector towards the front of the bike, behind the radiator, and not at the rear like YellowDemon is noticing?
Blue DL650K5
lajaro is offline
post #5 of 12 Old 04-25-2006, 05:35 PM
Correct. Also, since the reference is to a single connector, it's better not to use the frame for the relay ground. Find a black wire with a white stripe instead.
post #6 of 12 Old 04-26-2006, 12:58 PM
MATTMAN's Avatar
oops sorry, yes the grip wires on in the front.
MATTMAN is offline
post #7 of 12 Old 04-26-2006, 01:53 PM
daone
Well, what is that connector?
Hi, I bought an auxillary fuse box and want to power the relay that turns on that fuse box by the ignition.
I'm really interested to know what is that wire for?
If its not being used for anything I'll definitely connect the fuse panel relay wire to that.
post #8 of 12 Old 04-27-2006, 03:45 PM Thread Starter
I'm not sure what that wiredoes but in the end I vampired into the registration light to power the relay.
The relay doesn't take much and it works fine.
post #9 of 12 Old 04-29-2006, 03:56 PM
What sort of connector did you use to tap into the Reg light??
foot is offline
post #10 of 12 Old 04-29-2006, 05:44 PM Thread Starter
I used a Snap-Lock Automotive Cable Connector.
Its not what I really wanted to do being a brand new bike but it works and the finished result makes it very tidy.
I'll try put some pic's on of the installation.
