1000 shifter mod - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 07-20-2009, 10:23 PM Thread Starter
LoneStrom's Avatar
1000 shifter mod
I just put on some KLR pegs and they are great.BUT now with offroad boots ( size 11 ) I can't get my foot in between the peg and the shifter.I tried adjustments and they worked a little but not good enough.Has anybody found another shifter that is longer ( say 2 inches or so ) that works??.I was thinking of one that bolts straight onto the shift rod with NO linkage.The touratech one LOOKS like it bolts to the rod but It doesn't say.I live 2 miles from Touratech so I will go down there and see if they have one to look at BUT knowing them it will cost atleast $100.00...
LoneStrom is offline
post #2 of 12 Old 07-20-2009, 11:25 PM
Might try one from a DR650.......
post #3 of 12 Old 07-21-2009, 09:17 PM Thread Starter
LoneStrom's Avatar
Good idea,I will look into one.
Thanks
post #4 of 12 Old 11-30-2009, 11:19 PM
fredellarby's Avatar
This came up on the 650 threads. I have the same pegs and oversize feet. the DL650 shifter is no better.
I bought a steel shifter and am having a 2" extension added in the middle.
Fred
I'm not always sarcastic.
Sometimes I'm facetious.
Or ironic.....
If a tree falls in a forest and lands on a politician, even if you can't hear the tree or the screams, I'll bet you'd at least hear the applause.”
Paul Tindale
fredellarby is offline
post #5 of 12 Old 12-01-2009, 09:22 PM Thread Starter
LoneStrom's Avatar
I put a DR650 shifter on my 1000..Works GREAT..gave me almost 3 extra inches and NO linkage !!.ALL this for $16.99....
1990 Yamaha XT350
2012 Honda NC700X BDR express......
1994 GS500..DORA THE PURPLE EXPLORA
post #6 of 12 Old 12-01-2009, 10:31 PM
Anybody know if this would work for the much better 650?
Fred
Or ironic.....
Paul Tindale
post #7 of 12 Old 12-01-2009, 11:14 PM Thread Starter
LoneStrom's Avatar
Nope it won't.You have a reverse shift pattern.You would be 1 up and 5 down..
1990 Yamaha XT350
post #8 of 12 Old 12-01-2009, 11:30 PM
henerythe8th's Avatar
Another solution
Remove those KLR 650 pegs!
Then take them to the shop and take a grinder to the set of teeth on the front edges. Knock them down about 3/16-1/4 of an inch.
If you care to, then reshape the 'new' teeth with a dremel tool or carbide bit in the air die grinder.
I had a set of similar KLR 650 pegs. Replaced them with some quite modified stainless steel Moose racing pegs for a different bike and they have a profile similar to what I recommended above. Cures the 'fit issue'. Note that I did not modify the foot contact surface on the Moose pegs, but the rest of the peg to make it work with the Strom mount.
2011 MG Stelvio
henerythe8th is offline
post #9 of 12 Old 12-02-2009, 12:07 AM
Rats. Why can't anything ever be that easy.
(well, other than falling off a log, or so I've heard.)
Fred
Or ironic.....
Paul Tindale
post #10 of 12 Old 12-02-2009, 10:31 PM Thread Starter
LoneStrom's Avatar
Hey Henry..
Check out the PNW section,We are having a ride this weekend,maybe you could make it.
1990 Yamaha XT350
