How to grip removal for heat elements needed - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 07-20-2009, 07:28 PM Thread Starter
Send a message via Yahoo to viclava
Looking for a tutorial on how to remove the grips and place the grip heaters on the bars then reinstall the grips, without damaging the oem grips. I was also hoping somone has done this that has also installed the Vistal universal cruise control. I had one already installed on my last bike, a ST1100, and they worked awesone with the Vista cruise, but I didn't install them.
Thanks in advance for any assistance,
Scott
viclava is offline
post #2 of 7 Old 07-20-2009, 08:44 PM
DblD's Avatar
I don't have any experience with heated grips but I do know compressed air is the way to go if you want to get your OEM grips off. To put them back on just wet the inside of the grip with rubbing alcohol and they'll slide back in place. The alcohol dries up pretty quick so don't dilly dally.
[SIZE="1"]2006 V-Strom 650, 2005 KLR 650 (Sold), 1998 KLR 250 (Sold), 2000 Kymco Cobra Racer (Sold, it was a scooter - does that count?), 1978 YZ125 (Sold), 1989 KX 125 (Sold), 1984 DR 125 (Sold), Misc Mopeds (Sold)[/SIZE]
DblD is offline
post #3 of 7 Old 07-20-2009, 10:30 PM
I installed grip heaters on mine, under the OEM grips. Just pry the grip loose in one spot using a long, thin screwdriver. Work it all the way through the grip at that one spot, then start to roll it around the grip, and it will all loosen. I used hair spray for the adhesive to re-install the grips, as it always worked on my bicycles, and they have not come off in 4000 miles. Just make triple sure that you have the correct grip heater on the correct side.
eegah is offline
post #4 of 7 Old 07-21-2009, 04:20 AM
mikefryman's Avatar
I used a coat hanger and made a long rod with a crank bent on the end. Start it in and turn the crank end. It works around the grip loosening. Got this method from a Harley forum. It worked well.
Mike
mikefryman is offline
post #5 of 7 Old 07-21-2009, 09:49 AM
I successfully used the screwdriver method to remove the grips on both our bikes. Reinstalled over Symtec heaters using slow-cure/hi-temp epoxy. They slid right on.
Dranoel is offline
post #6 of 7 Old 09-30-2010, 12:42 PM
Ol_Baldy's Avatar
How to: grip removal for heat elements
Ditto for these replies. WARNING. Make damn sure the heating elements are hooked up and working properly before gluing the grips back on.
Shiro nakama nijuu-ni - White Wee-Strom #22
'10 - DL650A (still my main trekker)
'11 - Suzuki DR-Z400sm (now modded as a Funduro)
'15 - Kawasaki Concours 14 (the Green Monster)
'65 - Honda Cub 50 (gone long ago but not forgotten)
Ol_Baldy is offline
post #7 of 7 Old 10-12-2010, 07:52 PM
October in Maine....I really MUST GET HEATED GRIPS...brrr...
dtrembley is offline
