Stebel horn update - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By larolco
  • 1 Post By nvr2old
post #1 of 9 Old 06-03-2019, 03:03 PM Thread Starter
Stebel horn update
Looked up Steble horns after there was a freebie mount offered on the forum.
I got a Nautilus horn a while back. Never tried it and when i did, jumped it directly to the battery. A whirring sound and feeble squeak emitted for the legendary device.
Wow, POS. So I looked it up in the Strom library. Plenty of suggestions but nothing seemed to help this device. I tried putting my fingers over the small holes of the diaphragms, some improvements. So I taped over those hole, got a better squeak. By applying pressure to the diaphragms the horn started to work as it should. So I got a couple cotton balls and stuck them under the plastic caps that cover the diaphragms. Now it sounds good.
But I'll need to tape over the periphery of the plastic covers to keep moisture out of the cotton balls.
Reminds me of my Fiamms I had on my beemers. Loud when new but feeble when not used for a long period. Then it took a lot of massaging to get them functioning again. my Fiamms had a screw on the diaphragm and could be adjusted. You could make them sound weird.
Some of Y'alls like sounding the horn to let folks know you are there or to stimulate drivers to move when the light turns green. That probably keeps your horns at peak working order. For those of us that don't and can't find the horn button without looking, our horns suffer from atrophy.
post #2 of 9 Old 06-03-2019, 03:29 PM
larolco's Avatar
Mine lasted about a month and then behaved like yours. Totally unreliable and.... gone.
Dual freeway blasters now.
BTW: I regularly find an excuse to honk at somebody just to make sure the horns work when you need them. And occasionally, I need them.
DesertBike likes this.
DRZ400SK17
larolco is offline
post #3 of 9 Old 06-03-2019, 06:32 PM
nvr2old's Avatar
Put one on my 05 in 07. Did like yours and slowly got worse. Found a suggestion somewhere to flush it with WD-40. Did a couple cycles and it was like new. Stayed good after that for 8 years and 70-80,000 miles. I did exercise it regularly.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #4 of 9 Old 06-03-2019, 08:54 PM Thread Starter
Nrvr2old, where did you spray the WD40? In the holes in the diaphragm under the rubber cover or up the air intake?
post #5 of 9 Old 06-03-2019, 09:19 PM
Stalky Tracker's Avatar
Curious too?
I have had mine for 11 years and it has worked flawlessly (knock on wood).
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #6 of 9 Old 06-03-2019, 09:31 PM
blaustrom's Avatar
Same here. It has to be mounted close to vertical and you must make sure water will not get into the inlet. I silicone caulked every crack and seam the unit has and it's been reliable up till now.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #7 of 9 Old 06-03-2019, 10:15 PM
nvr2old's Avatar
Sprayed it down the horn outlet.
notacop likes this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
nvr2old is offline
post #8 of 9 Old 06-03-2019, 11:43 PM
larolco's Avatar
I'm pretty sure rain was the death of mine. I'm a wet-weather rider.
DRZ400SK17
larolco is offline
post #9 of 9 Old 06-19-2019, 11:14 PM
Travisaurusrex's Avatar
Hi All,
My two cents--I put a Stebel on this past fall and mounted it with a tab I made from some scrap aluminum bar stock I had laying around, to an existing threaded connection on the left front of my motor. I ride year-round in NYC and upstate in rain, snow, offroad, etc. and its held up just fine without any mods or issues. I got it on Amazon for $35 or so and used the usual $12 harness Amazon recommended/that most buy with it. Just barely long enough with my routing/wire shroud, but its a fused connection straight to the battery that has served me well---and scares the #$%^ out of oblivious jay-walkers on their phones and terrible/senseless/distracted drivers alike
"How unhappy is he who cannot forgive himself."
-Publilius Syrus
Travisaurusrex is offline
