VStrom 1000 lowering links - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 19 Old 06-02-2019, 09:03 PM Thread Starter
WANDRR's Avatar
I just bought a 2008 VStrom 1000 and it has lowering link installed. I want to set it back to stock height, or a little taller, like my other VStrom. I can't find a video or any discussion on this for a 1000. Has anybody done this or if there a video or there about this?
Sent from my moto g(6) play using Tapatalk
WANDRR
06 K12LT
05 DL1000
BMWMOA, IBA, MTF
WANDRR is offline
post #2 of 19 Old 06-02-2019, 10:19 PM
Stalky Tracker's Avatar
I believe the stock dog bones are 140mm so you could pick up a set of OEM links and install. The installation is pretty straight forward: https://www.adventuretech.biz/dl650-...tructions.html
Or if you want to raise it a bit, see Rick at AdventureTech: https://www.adventuretech.biz/gen-1-...-1-dl1000.html
richlandrick, WANDRR and Gert like this.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #3 of 19 Old 06-03-2019, 09:02 AM Thread Starter
WANDRR's Avatar
Thanks. Do you think this can be done laying the bike on it's side?
WANDRR
06 K12LT
05 DL1000
BMWMOA, IBA, MTF
WANDRR is offline
post #4 of 19 Old 06-03-2019, 09:25 PM
I suppose you could. Bolt side up. Gas tank near empty.
I would find a way to lift or steady from above, garage roof truss or tree limb and some straps.
1974 Suzuki TM-250
1965 Suzuki 80
post #5 of 19 Old 06-05-2019, 02:41 PM
I might be interested in the lowering links when you change them---
WANDRR likes this.
posumman is offline
post #6 of 19 Old 06-05-2019, 03:32 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
I'm sure if you think about it long enough you can come up with a better way of doing it than laying it over on its side. Like supporting the bike under the engine maybe?
The stock links are inexpensive and available form any Suzuki parts warehouse (e.g., cycle parts nation). Our instructions should be a big help no matter what links are being installed. Taking the weight off the bolts does wonders.
richlandrick is offline
post #7 of 19 Old 06-05-2019, 05:16 PM Thread Starter
WANDRR's Avatar
I only thought that because I changed a flat in eastern Europe like that. I travel and don't have a home so sometimes easy is easier.
WANDRR
06 K12LT
05 DL1000
BMWMOA, IBA, MTF
WANDRR is offline
post #8 of 19 Old 06-05-2019, 06:10 PM
Geeze,
If you are near clover SC give me a call or PM. We can do it in my shop and you can tell me stories.
If you let people know where you are you might find similar offers.
WANDRR and Jeff DeWolfe like this.
post #9 of 19 Old 06-05-2019, 07:26 PM Thread Starter
WANDRR's Avatar
Geeze,
Thanks for the offer. That is very kind of you. The closest I will be is the start of the IBR in Greenville. I'm camped up in NC now.
WANDRR
06 K12LT
05 DL1000
BMWMOA, IBA, MTF
WANDRR is offline
post #10 of 19 Old 06-11-2019, 07:41 PM Thread Starter
WANDRR's Avatar
I laid the bike on it's right side, 20 minutes later the links were changed. So easy.
richlandrick and Jeff DeWolfe like this.
WANDRR
06 K12LT
05 DL1000
BMWMOA, IBA, MTF
WANDRR is offline
